Every time I see that pic I sigh...
Of course it's a 'chop. Trust me, the moment the new GT-R pics are leaked/released/stolen and distributed, your SAU bruvahs in Japan will post it all over this forum.
Back to the pic, it's clearly a photochop... just look at the mirrors in relation to each other! WACK. The right hand side headlight doesn't look legit either.
the pic is to "clean" to be real.... drawn in daw handles? so clean you would expect to see evidence of a driver imo.
however I read on a UK forum 2/3 months ago that a bloke had seen a car testing at night, not far from the Lotus development centre (they are reported to be working on the handling) , he believed he'd seen the R35. He couldn't discribe the front of the car, but sed when it overtook him he got a good look at the side windows and rear. From his discription I assumed he'd seen a V35 (at the time there were only three in the country). When this pic was published here he sed that that was what he saw. Forget the front, if you look at the window line and rear quarter there is a resemblace to the V35!! so although I believe the pic to be CG'd ........ intriguing init.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
