RBVS,
Race cars also don't use a hollow cyclinder (knocked out cat) in the middle of their exhaust, they use a straight through pipe as they know the hollow cyclinder increases back pressure.
What boost setup have you got to be able to run a minimum of 14psi?
Obviously a 14psi wastegate? or a stocker RB20 type wastegate with a gated bleeder?
There is no doubt there is power to be had if the cat is replaced with a straight through pipe.
Providing the cat you are using supports the kind of exhaust flow levels you are after then a cat is not going to restrict power hardly over a cat converter that has had its guts knocked out. Thats providing the cat is in good working order to begin with. A typical symptom of a stuffed cat is the lack of boost.
I know they wouldnt use a a knocked out cat they would'nt have a cat at all., LOL. I have autronic sm2 which has boost control. I tuned the solenoid to stay closed so it was basicly a pipe from the plenum to actulator. With the cat hollow the exh would flow very well and the wast gate could no flow enough. (needed to be made bigger to run less boost.) The point is that when i put the un guttered cat in it restircts the exhaust enough to make minuim boost 12psi. with just a gutted cat as only change it will run 14psi in the top end. (the ungutted cat is in new condition)
roy,
i new someone was going to be a smart ass and tell me that some race cars use cats, but if they didnt have to do you think they would?
  • Replies 45
roy,
Settle petal, not beign a smart ass....just trying to highlight that thanks to their use in motorsport, there are cats available that dont hurt performance.... hopefully one day the technology will filter down to us.... to tar all cats as power robbing is a little generic and not true.
A concern is that in NSW they have started setting up roadside defect stations which include EPA testing.
For those betting on putting a cat back in before you get tested watch out...these ones are on the spot.
For road use, I'd personally suggest a full NOS install instead of knocking the cat out....the fine is far less and 100hp is a hell of a lot better than 5rwkw.
I don't think anyone has a problem with no cat for track use :D
agreed, good point. I not saying all cats are crap as general, but looking at a stock cat i disagree that "if you dont have a pipe through the cat then it does 'nt make a differnce to flow". the stock cat is small and basicly with the mesh knocked out is a oval ''4 pipe. As thats what some people are sudjesting.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
