After some advice, havent been able to find anything indepth while searching.
Having some electrical issues with my R32 GTS4 4 door at the moment
When I turn the key to accessories, the speedo and tacho are flatlined at 0, I see the torque gauge for the 4wd system go to the 12 oclock position , from memory the other dials appear okay. When I start the car the tacho is at 0, and doesn't move.
I pulled out all the fuses and checked them, there was one blown 10amp fuse, which I replaced which didn't fix the issue.
The fuse I replaced has blown a number of times in a matter of a day it appears to be the door power window fuse as that's what affected, so i presume something somewhere in the electrics is not right.
A couple of things:
I am running a Vipec ECU. It would normally cycle the tacho from memory to redline when you first put the car on accessories, that doesn't happen anymore
After some advice as to what to check next before I get an auto electrician to check the car.
thanks
https://www.sau.com.au/forums/topic/443440-r32-gts4-electrical-issues/
  • 1 month later...
  • 3 months later...
Update, Looks like I may have found the issue, both tailight inner brackets were lose, meaning the wires were at an unusual angle, need to wait to see how it goes, but the car hasn't blown a fuse yet after fixing this issue this morning.
Dead instruments is common on old Nissans. My Stagea speedo, tacho, fuel gauge and temp gauge sometimes die for no obvious reason and then come to life. Some people say you need to take out the cluster and apply heat to the soldered joints.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
