I was talking to a engineer today about cars and shiny things and his professional opinion was that if a strut brace was not a solid item it is useless.
He was looking in the engine bays of my MX5 which has a one piece strut brace and a 180 with a (insert brand name here) strut brace with a hinge thingie at the tower which connects the mounting brackets to the brace.
Thoughts....
https://www.sau.com.au/forums/topic/443450-strut-bracing-fixed-or-useless/
Well, if you look at it critically......the whole point of a strut brace is to stop the tops of the suspension towers moving relative to each other. So in that case, you can have pin joints at each end of the brace and so long as the brace is sufficiently stiff that it won't deform itself under load, then it will hold the tops of the towers at the same distance relative to each other all the time. At least it will along the line of the brace. It can't do anything about motions out of that plane (ie fore-aft movement of the towers).
On that basis a brace will almost certainly improve the "stiffness" of the chassis. What it really means is that when you have really big loads being put into one tower (ie the outside wheel in a corner) then the brace will transfer some of that load into the opposite side of the car and the total deformation of the chassis will be less. Depending on how flexible the chassis is, you may or may not notice a benefit.
But, pin joints allow the rectangle that consists of the crossmember, the two towers and the brace itself to freely deform. If you take the assumption that those 4 elements are all at right angles to each other (they're not, but it helps to understand what I mean if you do), then putting a big load into the top of one of the towers in the direction that the brace runs will cause the top of the rectangle to want to move to one side. This will deform the rectangle into a parallelogram. Pin joints allow this to happen freely. If the brace has no pin joints at the ends, then the connection of the brace to the top of the tower now allows it to resist moments (torque) as well as simple sideways load, and will add additional "stiffness" into the structure. What it does mean though is that if you do not have pin joints then the actual brace itself needs to be much thicker/heavier/able to withstand bending load because the act of resisting the moment load input at the tower/brace joint will put a bending load into the brace itself. If you have a skinny little tubular brace without pin joints, then it will deflect upwards in the middle during heavy loading from one end, and will not do much to stiffen the chassis as a result.
Edited by GTSBoy
That's along the lines of what he was saying. I've seen some hard core looking strut braces on some of the boys cars, I may look into a big arse solid bar to replace my standard solid one.
Awesome reply BTW.
It would. That's really the only sort of strut brace that makes any practical sense. In the rear they tie them down to the boot floor between the towers and that would have to help as well.
Ideally in the front, you'd want triangulation in the vertical plane as well (or instead) of the horizontal plane. But there's an engine in the way which kind of ruins that! Horizontal triangulation at least stops the towers being able to move fore-aft relative to the rest of the car. That's actually probably not too much of a problem on quite a few cars anyway because the inner guards will be quite strong in that direction, but some cars would no doubt see a big benefit.
Of course, on Skylines, the question is a bit moot anyway, seeing as they don't have struts.
They do a little bit, but it is nowhere near as bad as on, say, an S14. The upper suspension arm mounting points on the Skyline are still attached to the "strut towers" so are subject to whatever deflection turns up in those structures. But if you have a look at them, they are a long way down compared to the tops of struts, in fairly strongly built structures. The amount of deflection that gets into that part of the car won't be heaps.
Anecdotally, plenty of people report that putting a strut brace onto an R chassis car makes it feel better. It's probably less about stopping the upper suspension mounting points moving around than it is about simply tieing the front of the car together a little better. Overall chassis stiffness improves, and so then does suspension performance.
Thos will be falling on to alot if deaf ears i think, but i recently fitted a b-pillar brace which made a noticable difference to reducing chassis flex (rear inside wheel lifts more in corner, less felx/droop), whereas i couldn't feel any difference with front strut tower brace.
I think the front strut brace in mine made a little bit of a difference. Not huge but it did feel a little more solid in the front. But I basically got mine for free so wasnt really hanging on it making a difference at all
that might be just the feeling, if there was actual numbers or a test done to see the difference. The thing is that human sensation can hinder the actual result even if it was a blind test, maybe a race car driver can tell. IDK.
yeah no shit it was just the feeling, how many ppl do you know outside of car companies that have rigs to test chassis flex....If you drive it and it feels better to you, then it's a good result. i actually didn't think it would do anything, was just curious, so not like I had convinced myself it would feel better with it fitted.
After I fitted and tightened the f**k out of the rear strut brace the inside rear wheel lifts off the ground driving into a mates driveway. Having never done that before it makes me think there must be a difference. It is a standard R33 GTR rear brace and I think its the same as the gts-25t S2 factory brace
I have a typical just hap strut brace and it makes a subtle but entirely noticeable and repeatable difference.
R34 had one stock and I'd be confident it's for a reason. The R34 chassis was much more rigid than R33.
My assumption (and assumptions are like arse holes, everyone has one) is if it has a hinge at the tower it will pivot under load and thus not lock in the suspension geometry (the only thing trying to lock it in a the friction from the ?M8? bolt trying to restrain a lever of around 1.5 meters, not likely).
It may keep the towers at the same distance from each other on the X axis but the Y axis will move around.
Every stock brace I've seen is solid, every good quality (big dollar shiny race car type) brace I've seen is solid.
Are the hinged braces like the old exposed pod filters, i.e. looks good but does not perform (apart from the seat of the pants dyno results).
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
