Imported standard from Japan in 2007. $30k+ spent in mods, everything top quality. All receipts and dyno charts. Multiple tunes for PULP, E50 and E85, switchable via laptop software.
Runs perfectly, makes big power. I'm getting married, and unfortunately the fiance wants it gone...!
Safe, reliable 300rwkw @ 20psi on E85. (270rwkw on PULP)
Garret GT3076 internally gated turbo (.82 A/R)
Haltech P2000 3 bar map sensor ECU (USB connector in glovebox for laptop tuning)
Highflowed RB25 injectors (~800cc)
Greddy Profec B spec II boost controller
Haltech Wideband Oxygen Sensor (w/ closed loop fuelling)
Standard B.O.V. plumbed back into intake
Bosch 040 High Capacity Fuel Pump
Custom built Autosport Engineering crossflow intercooler
Apexi Power Intake Air Pod
Custom stainless intake pipework and cold air induction
3" single dump pipe
Exhaust Technology custom 3" mandrel exhaust
Exhaust Technology racing cat
Jun BL 3" resonator and spiral cannon
Aftermarket 52mm alloy radiator
Exedy Heavy Duty ceramic 5 button clutch
Brand new Nismo 1.5 way mechanical LSD
HICAS locker bar
Brand new DBA T3 slotted brake rotors (front)
Brand new brake pads all round
King Springs lowered Coil Springs (standard springs come with car)
Whiteline Control and Upper Radius Arms (camber adjustment)
Whiteline Subframe Align & Lock Kit (polyurethane diff bushing, aka 'pineapples')
Speedy Inferno rims (black gloss, machined rim)
19 x 8.5" front - 235 x 35 tyres - (brand new)
19 x 9.5" rear - 265 x 30 tyres (good)
Standard rims with near-new tyres will also come with the car
Nismo Clear front & side indicators
Alpine CDA-117 head unit (CD/MP3, USB & iPhone connector in glovebox)
Parrot Bluetooth module and microphone
Pioneer JDM Carrozzeria 3-way splits (front)
All wiring to boot for amp and subs
Looking for $16,500 ono. Bargain.
Cheers.
Guy
0407 025 822
[email protected]
(will post more photos soon)
https://www.sau.com.au/forums/topic/443456-300rwkw-1998-r34-coupe/
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
