Ok so I'm having a few problems with my 32 (turbo) I bought the car about a month ago, all seemed fine on purchase, besides bulk unburnt fuel. I did a service myself (spark plugs, oil etc) and at the same time before I went for a drive I bumped up my fuel pressure reg from 20 to about 40. Started it up it sounded like aids, real gluggy and wobbly on acceleration, was told it was a misfire, and perhaps I've drowned my injectors with fuel due to bumping up the fuel reg, or it's a spark plug issue.. I turned my fuel reg back down and it's made no difference. I have 440cc injectors, yellow jacket coil packs and iridium spark plugs. Any help on what the problems are and how to fix would be very appreciated. Thanks guys.
What ecu?
why are you just messing with the fuel pressure randomly?
You can't drown injectors, you can flood the 3ngine and or foul plugs.
In summary your problems are you are doing random things with no clue and that will never work out well for you.
So don't randomly mess with it.
Either spend ages reading and learning, or take it somewhere and get them to see what's going on.
For the time being busy yourself by doing a pressure test to see how many boost leaks you have. Search how to do it.
If you are in NSW, anywhere between Sydney or the Gong, I can have a quick sticky beak for you.
or if you can elaborate on 'highly modified' to get an idea of what the tune should be like I can help.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
