My race only JDM R35 GT-R is for sale. I haven't used it in nearly 12 months as I'm racing a Radical instead.
Has a tonne of parts and can be used for Targa, Sports Cars / Aust GT's or else just use it as an epic track day / WTAC car (there is even an R35 specific class at WTAC now).
Price is $95K but has well over $100K worth of parts and upgrades.
Contact Andrew on 0419 375 140
Parts include:
Racepace built VR38DETT (New block, crank, forged rods, pistons, bearings) (Brand new - 0km's on motor other that Dyno run up).
Secondary oil cooler
Genuine Spec V turbo’s
ID1000 injectors
HKS fuel pumps
AMS custom intake piping
AMS intercooler
DBA upgraded inlet pipes
Dodson dump pipes
Full Akrapovic titanium race exhaust
Cobb ECU with TCM (gearbox) module
Syvecs ECU
New 2012 upgraded gearbox (better design than the 2007-2010 OEM box – far more reliable)
Spare original gearbox with Dodson upgraded parts including clutches and gears (over $15K worth of upgraded parts. There is no Park lock in this gearbox however. All the upgraded parts could be used in the new gearbox if desired. See parts list at bottom)
HKS Transmission cooler
Willall rear diff cooler
KW 3 way race suspension with multiple spring sets
Dodson adjustable upper front arms.
Whiteline front and rear sway bars.
ARP wheels studs and Project Mu racing wheel nuts.
Hardrace rear arms and toe rods.
Custom carbon brake ducts (Kelly racing)
Braided brake lines
Willall Brake Waterspray kit.
AP rotors / Project Mu race pads
Works Bell quick release steering hub with moving paddles. OMP wheel.
Sparco Pro ADV race seat
Scroth Enduro 6 point harness (HANS) (1 year old)
Motec CDL3 dash and HD camera.
Fire bomb
Seibon carbon bonnet
Seibon carbon side skirts.
Seibon carbon rear lower apron.
Top Racing dry carbon front guards
Race Glass Fiberglass doors and lexan side window’s (including rear ¼’s).
Squarecraft Carbon Mirrors.
Top Racing dry carbon front bar + diffuser.
Aeromotions R2 wing.
Seibon carbon rear boot lid and OEM style wing.
All other OEM panels including doors / window’s / mirrors etc are available as well.
Dodson built gearbox parts
PPG straight cut 1st gear and input shaft
Dodson Input shaft seal
Dodson FWD Output shaft
Dodson FWD Pinion Gear
Dodson Blueprinted Oil Pump
Dodson Reusable Filter
Dodson High Temp Diff Cover Seal
Dodson Magnet kit
Dodson GR6 O’ring kit
Dodson Actuator shim for GP1 and GP2
Dodson Mechanical Circlip 1 & 2
Dodson 4WD Gear Lock and circlip Holder
Dodson Sportsman 8 plate clutch kit.
10273706_10152863296467564_6793175972041
1075479_10152068945437564_1672132174_o.j
Can also see some of the build details here:
http://www.skylinesaustralia.com/forums/topic/425308-snowys-production-sports-r35/
https://www.sau.com.au/forums/topic/443484-race-only-r35-gt-r/
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
