I'm using a provided martini livery
I noticed that. It looks great.
If I get time I might make something for the mx5.
So next month is set for Summit Park Raceway on the 6th of August. Get your practice on and see everyone at the track!
Sound good! Time to get used to the mx5
And you get to see it every time I'm lapped :D
Haha hopefully not as much next race!
Mind you I've been playing this game for years and I had 31 incidents that race.. Never have I had so many in a race that length.. :/
  • 4 weeks later...
So just over a week till the next round! Everyone liking the new update build of iRacing? I'm yet to have a go run since updating so I better get on and do some prac me thinks! :P
Wednesday, Wednesday, Wednesday!!! Time for Round 3 @ Summit Park raceway! Not many points between places after just two rounds, will round 3 be the one that spreads points out or tightens places up!
Guest
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
