HI Guys
some help here please
so I have rebuilt my rb26 from scratch, flowed and ported head with Tomei poncam type-b
so first install with rc750cc injectors and Mine's mafs brings no joy, idle is rough afr erratic, i can lean the afr out completly and it would still run rich
replaced the mafs with old mafs and old injectors still the same problem
the car came with bov's that vent to atmosphere I have disconnected them they are not leaking at all when disconnected
when driving the car it hesitates alot but when turbo's start making neutral pressure 0bar the AFR starts to lean out then when on boost its start riching up like You would expect and it feels pretty solid on boost with no issues
any suggestions
could the cams perhaps be out to overlap and cause an issue like this?
Thanks hope somebody can shed some light
https://www.sau.com.au/forums/topic/443517-gtr-low-rpm-richness-and-hesitant/
are you using the same map loaded on your powerfc as before? i recommend, if you can...to do a data initialise (wipe) of your power fc and then reload your maps...then run through the startup procedure for the powerfc again. if you can't do this...i'd recommend taking it to a tuner that can.
I have initialized the apexi so with stock injectors and mafs you would expect it to idle like normal but no luck, its just beyond rich and adjusting the correction does not lean it out
I am thinking that the ovelap of the cams 35degrees is maybe losing some of the air in the chamber and causing the richness
but driving at low RPM is also horrid so much hesitation
if it's a fresh build perhaps cam timing is out? how big are the type b's? I thought they were pretty streetable AFAIK.
Also, not that it would matter in idle but you can't tell if the Bov's are leaking without pressure testing
I sparyed some quick start in the bovs while idling with no change in idle
paid so much attention to the timing when assembling the motor but will chack again
does anybody know what would be safe degrees to start off with when degreeing these cams could maybe close some of the overlap
cam specs below
B
260°
260°
9.15mm
9.15mm
110°
115°
0.45mm
0.38mm
You can calculate overlap here https://www.rbracing-rsr.com/camshaft.html
with these settings
Tomei Poncam B
Intake 260 degrees 20 BTDC 60 ABDC 110 degrees
Exhaust 260 degrees 65 BBDC 15 ATDC 115 degrees
check your o2 sensors.... They could be poked. unless you have o2 feedback turned off. either way if you are not able to tune it.. try getting it Tuned.
The cams wont cause the issues you are having, unless installed incorrectly.
I only recently installed type B's into my neo and it has been running fine with no change to the tune (havent had a chance to get on the dyno yet)
ok so Update
I checked cam timing according to true TDC everything is spot on
I did a compression test on the fresh motor couple of km's on it and it was super low 6bar 87psi cold, could be due to cams and not run in yet
I am at a loss here and I feel I want to burn this fekker :/
so when on idle now it would be on 12 afr but very rough as soon as i want to rev it up slowly it starts leaning out up to the point that it wants to die
when I leave the throttle it wants to die aswell then i need to sort of keep it alive, I am now getting a set of standard recirc bovs in hope that that can help but wont bet my life on it
Yes I do have bigger injectors
I have RC pl4-750d 750cc injectors, played alot with the settings and ended up on 59.2% and +0.24 lag time
this seems to work best, if anyone has used these injectors with apexi would you mind sharing your experience and settings please
try this:
  1. Reset PowerFC
  2. Set scaling in ball park
  3. Select correct AFMs
  4. Turn off O2 feedback
  5. Start/Rev car up to around 3000 rpm & hold (when warm)
  6. Adjust scaling till car hits stoich (roughly)
  7. let it idle, then adjust lag time till idle is stoich (roughly)
  8. tidy up map
  9. Enable O2 feedback
  10. Take to tuner
These are the Lag times i could find for the injectors.
Injector Flow CC/min Flow LB/Hr Ohm 10v 11v 12v 13v 14v 15v
Nissan Skyline GT-R 440 42 2 1.35 1.12 0.96 0.85 0.76 0.65
Nissan Skyline GT-R 440 42 2 0.7 0.61 0.54 0.48 0.4 0.35
RC Engineering 750 71 3 0.57 0.48 0.38 0.31 0.24 0.17
RC Engineering 750 71 3 0.88 0.66 0.48 0.32 0.18 0.05
RC Engineering 750 71 12 1.36 1.12 0.92 0.76 0.63 0.5
Edited by Badgaz
Update
I think I resolved the issue here
did a silicone grease trick on the ignition coils
degreed cams a bit +2 intake -4 exhaust
installed stock bov's recirculation
now with the setting of 59.2 and 0.24 on the injectors it idles almost perfect 14.7
acceleration is also almost find just a bit of leanness when initial pushing of the throttle
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
