I had them on my car when I got them... I drove from Melbourne to Sydney with them flat... and pumped them up, and they lived for a good year+ after that.
Pretty sure I'm the only person other than drug traffickers who got some use out of them!
  • Like 1
  • 3 weeks later...
the only advantage is not carrying a spare. Other than that they're expensive, so spend your money on a better quality tyre instead. It's annoying in beemers etc where there's no well for a spare
I don't even bother carrying a spare anymore unless I'm going on a roadtrip. Around town I'll just ring the missus or a mate
Edited by mistermeena
Haha .. OK good point!
Run flats are usually more expensive than standard tyres too. Id rather get nice sticky good quality high performance tyres than run flats. Good quality tyres are harder to get punctured anyway, from personal experience :P
Not for me either.
I am a legend at dodging punctures, in particular those spike strips the cops use.
Punctures.
Not even once.
Haha .. yeah, me too.
Avoiding the spike strips in Need For Speed gave good practice :)
for what its worth ill go against all coments so far i have them on the front of my 33 (just because i was broke and had bmw wheels with the right size) but after having them on the fron with the stock 55 profile i found them to handle a heap better around corners they are so stiff it isnt funny they were a prick to fit and used heaps of weights to ballance (i do all that myself) i wouldnt go back to normals ever.
However if your running bigger wheels then they wouldnt have sidewall flex anyway and itd be a total waste of cash.
  • 1 month later...
and from what ive heard you cant put your foot down with runflats and forget a burnout or even kicking the car out apparently you get major wheel shakes when trying to slide although this was the opinion from a friend with them on his prelude
it doesn't go that bad for a fwd hahaha anways its not my car so sucks to him. but serieously hes put some work into it and it used to beat my old r31 rb30de+t although it only run 6psi boost so cant really compare it hahaha
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
