There are plenty of fuel rail kits out there, Plasmaman being on of the more expensive ones. I guess you are guaranteed it will fit under the plenum, although I usually recommend the Proflow ones since they modified them slightly to fit the RB25 better.
What the hell is a 1150cc Bosch injector? Seems every supplier is bumping the flow numbers just to make their stock sound better. At what pressure does it flow 1150cc? I assume we are talking about 1000cc EV14's here? If you are running e85 have you looked at the injectors designed for that? (Xspurt 1400's and ID1300's)
Will I be able to fit full length top feed injectors with a standard plenum on my rb25det using the proflow rail?
I know the aerospeed fuel rail also fits 3/4length injectors with the standard plenum.
he fuel pump as well will flow even more then 460LPH at a higher pressure.
I think he needs to learn a little more about his products, this is just plain wrong. The pump will flow much less as the pressure rises, as he would plainly see on the flow chart.
No, you would need the short injectors which come in many sizes, to fit easily under the stock plenum. I think you can squeeze 3/4 length in there, but why bother unless you already have them.
34 Neo runs 3/4 (55mm) top feed injectors stock.
i just havent heard of Xspurt before?
ID are a US reseller of Bosch ev14's. Somehow they got the name as the only place that can supply decent injectors in the world. Other companies also supply exactly the same injectors and modify them in the same way, Xspurt is made by a local Australian supplier, with local warranty.
Both 1150cc and 1000cc injectors are E85 compatible most others are not.
I would not be trying to screw over a long term customer lol
As scotty mentioned that is flat out wrong.
I don't think he is deliberately trying to deceive you, he just has absolutely no idea about what he is selling.
The info on flow of pumps or injectors is very easy to find on the net.
Remember, being a trader on here doesn't mean much.....
As far as I know, no-one makes a female adapter to fit the reg to an AN fitting rail. It's just easier to fit an aftermarket reg.
Otherwise retrofitting an RB25Neo rail is your only option.
nice....but for 69$ you could buy an aftermarket fuel reg...
