Hi all,
I have an Autoselect Carbon bonnet for my R34 GT-R and have fitted it to my car but my problem is with the locking latch at the front... basically it just wont lock down/in the latch assembly no matter how hard I push down.
I have played around with the latch assembly by removing the 3 x 12mm bolts that keep it into place and trying to move it up and down. I have also even tried to remove the springs and see if that would help at all but nothing. I've also tried adjusting where the bonnet bolts onto its hinges (near windscreen) and still nothing.
Definitly not a case of not pushing down hard enough as I hard a 'crack' sound when I really gave it some so I didnt press down any further :(
Here are some pics of the bonnet resting on the latch.
Any info/help/tips would be greatly appreciated :)
Cheers,
Glen
Edited by xanavinismo
I had a similar problem with a carbon bonnet without pins, unbolted the latch assembly and filed out the bolt holes so it could be bolted higher up gave it the extra height for the U clip to click into place
So you mean its just a simple matter of the U-clip not being able to go low enough? Hence why you have to had to mount the latch assembly higher?
If thats the case, how much higher did you have to mount it? Ie - like 5mm etc?
Cheers
The pins also hold the bonnet down so the front latch should be able to click in without any problems
Thanks for your input Longz, so you reckon if I get bonnet pins they can actually hold the bonnet down enough to help push the U-clip low enough to click into place?
Hey Glen,
How goes things mate ?
No, he is saying use the pins to hold down the bonnet, which is illegal in NSW :( even tho it works better on a CF bonnet, you can have them providing they are flush mount and not the only method of holding the bonnet down
Can the U get spaced down at all like with washers or some thing, how is it attached to the bonnet
Michael
These were the ones i used when running a z tune style'd bonnet
http://www.aerocatch.com/
I might have a spare set in CF some where in the garage brand new lol
But yes sometimes when i don't click the bonnet down enough i just use the 2 pins to hold it in place ( but like XKLABA was saying not legal )
Hey Michael :)
Yeah things are going good.
No you cant do anything with the actual U-clip but as Zac mentioned you can play around with the latch assembly and move it higher.
So Longz..... Michael (XKLABA) mentioned that you can have the bonnet pins providing they are flush with the bonnet like the ones you have, so yours arent legal?
Also, might be interested in your CF ones if their for sale?
I do recall that the flush pins are much more "legal friendly" as i have been pulled over by hwp a few times and they didn't care about the bonnet with aero pins ,
Let me get back to you it's been a while i need to look for it somewhere in the garage
P.S did you get a bodykit \ panel shop to install the bonnet for you ?
Hmm interesting.
Okay thanks for that mate :)
I put the bonnet on myself. I had to put the standard bonnet back on because I had to drive it and that clicked in just fine. The U-clip on both bonnets dont look that different.... thats why im like :verymad: wtf? haha
The law requires the bonnet have a two stage locking mechanism so while you can use bonnet pins they can not be your only method of securing the bonnet down
The ones Longs has are the flush mount ones, its the ones that has the pin exposed you can't have I case you hit a pedestrian they won't get cut up on the pins, frankly if you hit a pedestrian the pins would be less of a concern then the near two tonne of car telling them their somewhere they shouldn't be :(
Looks like the only way you will get that to work is reposition the latch higher
Getting out to the track much ATM ?
I had similar problems on my fg bonnet when i first installed it, turned out some of the underside of the bonnet itself near the latch was hitting and preventing clear access of the latch to the u bit, filed it back a little and it works fine.
Can you see any place that seems to be hitting something near the u metal??
Yeah Michael that looks like the only thing I can do, as well as the bonnet pins. :(
Ummm I havent been to the track in aaages but I definitly will once I get all these things sorted out. :)
Thanks for your input 75coupe, well I removed the airbox cold air feed and that didnt help. Doesnt seem to be rubbing on anything else...
in your case, what was ur fg bonnet rubbing on?
I never got mine to fit, after measuring the stock and aftermarket U clip the size difference was just to big, Flush fit bonnet pins and metal safety catch on the U clip so if the pins fail the bonnet won't fly up and smash the windshield/roof
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
