This has probably been covered before, but I thought I would start a new thread for some fun especially with the popularity of E85 these days.
So, post up times of completely unopened OEM RB26 GTR's 1/4 mile times:
A quick search gives me:
XRATED: - [email protected] (R32, 396rwkw)
Tynago: - 10.7@137 (R33)
DVS Jez: - [email protected] (R32, 402rwkw)
GO!
Sorry to get off topic here a little. Isn't that gtr still running a H box. Does anyone know.??? I've seen the attachment that makes it shift that way but I just can't remember the name. Help.
No, [NITTO] runs an OS88 Sequential 6-speed.
You are referring to the Ikeya Formula Sequential Shifter that can be used with the OEM H-Pattern:
http://www.nengun.com/ikeya-formula/sequential-shifter
GO!
wow... that was a long time ago..... that was before 98 was even available at the pump in Tassie, little own E85! ha ha ha
... well hoping to run a little quicker next year with a new engine (and everything else).
Cheers
Justin
Yeh I did 11.30 @ 127mph stock engine stock head 98 octane with t517z turbos
XKLABA did 11 flat I think stock engine stock turbos
11.3@125 stock every thing in full weight R32
11.1@123 new HG and big ends bearings on drag radials with 293rwkw
Would still be interesting to see the results, Simon.
Thanks for the info guys.
I would think that with these engines getting older (25 years now), that it would be hard to beat those previous times (10.6's!)
My 33 has run 11.5@126mph weighing 1760kg with only -5's, ecu, fuel pump and injectors on E85. Bigger cooler and exhaust should help.
I might give it a crack while I get my built engine ready and see what happens :D
Last year on a unprepped runway (Racewars) I did a high 10 @ 136mph with approx 640hp at the hubs
Same runway this year I was doing similar times and trap speeds but with a passenger and a full tank on fuel with around 700hp at the hubs revving to 8000rpm
With a few more revs and less 150kgs of passenger and fuel I would hope I'd be around 140mph+
Might give it ago when the drags open back up over here but the gearbox may not like it :yes:
Edited by SimonR32
I've often thought about getting a good condition unopened 26 and slappin on all my 'big' bits and seing just how far it would go. Willall did it back in the day, but with a freshened up 'to stock specs' engine... so it doesn't really count.
It'd be cool to run 9's/140mph+ on an un opened engine in a true street GTR. We'd allways be at a disadvantage to stipped out auto GTR's though.
J.
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
