I have the following items for sale:
RIPS 4WD sump adapter for RB30 all wheel drive conversion + RIPS 7L sump: $1500 not separating
100mm Trust FMIC to suit R32 (may suit 33), perfect working order. Has 2 small dents on top buy they don't affect the cooler: $800
Aftermarket Industries 2L surge tank with twin Bosch 044 pumps, lots of speedflow fittings and brackets, unused: $850
Located in Perth, can organise freight easily.
I can also do a package deal with this built RB30 short motor for $7000:
http://www.skylinesaustralia.com/forums/topic/443448-built-rb30-bottom-end-ready-to-bolt-to-rb26-head/
PM if interested,
Cheers
