All part have been on the car less then 1000km
plazmaman plenum and throttle body comes with all bolts $ 950
6boost high manifold $ 850
kompact turbosmart bov with gasket $100
50mm 6boost turbosmart waste gate with 17psi spring and v band clamps $450
z32 afm with harness $100
gt3076r .82 with turbo fittings $ 900
r34 gtt ecu with nistune $400
turbo to cat 3 inch exhaust with race cat $300
oil relocate kit $120
Siemens deka 550cc injectors with harness direct fit for the r34 gtt $210
if anyone is interested in all the part im willing to do a deal and il include a intercooler and piping with silicon joints and clamps and everything else needed
You can contact me on 0405659093 if u need any more details or anything else
I couldn't add all pics for some reason i can send them to anyone interested
thank you Simo
post-61653-0-29287700-1400919711_thumb.jpg post-61653-0-80486500-1400919844_thumb.jpg
https://www.sau.com.au/forums/topic/443575-r34-gtt-performance-parts/
guy and girls
the garret gt3076r is still up for sail it in perfect condition it will come with all fittings and turbo lines r by gcg and gaskets
turbo smart kompact bov is still for fail it has r34 gtt flang on it perfect condition
oil relocate kit is still for sail the lines are brand new never been used
turbo back exhaust
all the people that have got my other things can tell you everything was in perfect or new condition
everything has been on the car less then 1000km
Edited by grim reaper
  • 4 weeks later...
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
