All part have been on the car less then 1000km
plazmaman plenum and throttle body comes with all bolts $ 950
6boost high manifold $ 850
kompact turbosmart bov with gasket $100
50mm 6boost turbosmart waste gate with 17psi spring and v band clamps $450
z32 afm with harness $100
gt3076r .82 with turbo fittings $ 900
r34 gtt ecu with nistune $400
turbo to cat 3 inch exhaust with race cat $300
oil relocate kit $120
Siemens deka 550cc injectors with harness direct fit for the r34 gtt $210
if anyone is interested in all the part im willing to do a deal and il include a intercooler and piping with silicon joints and clamps and everything else needed
You can contact me on 0405659093 if u need any more details or anything else
I couldn't add all pics for some reason i can send them to anyone interested
thank you Simo
post-61653-0-29287700-1400919711_thumb.jpg post-61653-0-80486500-1400919844_thumb.jpg
https://www.sau.com.au/forums/topic/443575-r34-gtt-performance-parts/
guy and girls
the garret gt3076r is still up for sail it in perfect condition it will come with all fittings and turbo lines r by gcg and gaskets
turbo smart kompact bov is still for fail it has r34 gtt flang on it perfect condition
oil relocate kit is still for sail the lines are brand new never been used
turbo back exhaust
all the people that have got my other things can tell you everything was in perfect or new condition
everything has been on the car less then 1000km
Edited by grim reaper
  • 4 weeks later...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
