For sale is my 1997 Nissan Pulsar VZR. This car was specially sourced and imported by Iron Chef Imports and complied by JLM. I am the first Australian owner.I bought the car in
August 2012 with 62 000 genuine KM. This car was completely stock and has a full Japanese logbook service history from the day it left the Nissan dealer. It has been my daily and now has
88 xxx KM, and has been serviced every 5-10 thousand Km. All servicing has been carried out by JLM. The car now runs beautifully as i have spared no expense in
maintaining it, and since owning it i have replaced the following:
- Clutch
- Front brake Rotors
- All four brake pads
- Left and right front, outer CV boots (october 2013)
- Rocker cover gasket
- All coolant hoses
_ Radiator with SSS core (nov 2013)
-Front engine mount
-rear engine mount
- Vct solenoid (may 2014)
This car is a non accident car and the body is in excellent condition. Since owning the car i've had two panel beaters inspect the body and both have found that all
bolts , welds, seals and panel gaps are as per factory. The doors, boot, bonnet and guards have never been removed, and the chassis is very straight.
post-95869-0-56158000-1400984233_thumb.jpgpost-95869-0-34228200-1400984272_thumb.jpgpost-95869-0-42859300-1400984399_thumb.jpgpost-95869-0-88320700-1400984424_thumb.jpgpost-95869-0-30619100-1400984470_thumb.jpgpost-95869-0-99195800-1400984506_thumb.jpgpost-95869-0-42067000-1400984537_thumb.jpgpost-95869-0-90748800-1400984571_thumb.jpgpost-95869-0-43264800-1400984600_thumb.jpgpost-95869-0-69028000-1400984662_thumb.jpgpost-95869-0-33754600-1400984692_thumb.jpgpost-95869-0-61728200-1400984728_thumb.jpgpost-95869-0-58038600-1400984757_thumb.jpgpost-95869-0-23130700-1400984790_thumb.jpgpost-95869-0-85212000-1400984826_thumb.jpgpost-95869-0-43519700-1400984857_thumb.jpgpost-95869-0-03699200-1400984886_thumb.jpgpost-95869-0-75137300-1400984916_thumb.jpgpost-95869-0-82171600-1400987197_thumb.jpgpost-95869-0-16010700-1400987247_thumb.jpgpost-95869-0-23398900-1400987587_thumb.jpg
Having previously owned an Aus delivered Pulsar SSS, i can tell you that the performance of the VZR is considerably better and the NEO VVL also provides better fuel
economy. The VZR is also cheaper to Insure as it's 1.6 L engine does not classify it as a sports car. In short a perfect P Plater Car or a great daily that's still
plenty of fun on the weekend.
Car has 6 months rego.
I am selling to make way for a skyline. :D
All inspections are welcome, this is a very clean and original car. Condition will not dissapoint.
Location - Sydney
Price-$ 10 000 ONO
Please PM me for contact details.
Jason
Edited by the spruce moose
https://www.sau.com.au/forums/topic/443605-pulsar-vzr-sr16ve-iron-chef-sourced/
Recently i was given the figure of 12k to import a car similar to the condition of mine by JLM, that is if you are able to find one without accident damage.
As per the rules, if you are not interested in buying the car DONT post.
Thanks
nice clean example.
jump on http://forum.pulsar.org.au/forum.php maken an account and advertise. will be more likely to get interest there than here.
https://m.facebook.com/story.php?story_fbid=655958541140055&substory_index=0&id=109130862489495
Not sure if the link works, but it's for a n1 VZ-R selling for 12.9k.
Guess I will have to eat my words.
  • 4 weeks later...
  • 2 months later...
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
