Hi guys and girls just want to no what's the better ecu to run on my r33 gtst s2 my minds been in limbo for months now wondering what ecu to buy and what's your experience with the brands Or any other suggestion my setup gonna be hi flow turbo bosh 040 fuel pump z32 afm not sure on what size injectors to run oh and has anybody had experience with those forward facing plenuims on eBay are they any good.
go for cheapest.. probably PowerFC
HOWEVER, Haltech has about 1000000000x more features:
- flex fuel
- launch control
- anti lag
- flat shifting
- boost control
- internal map sensor, ditch AFM
- closed loop knock, wideband O2, etc.
- IAT input
- no need for stupid data logit boxes, direct USB
I personally would go Haltech, not bother with those dim sim Plenums and use the stock one.. afterall you're only using a high flow, which does not warrant a plenum upgrade.. save that money for a proper mechanic diff.
Thanks Luke and John haltech it is, would this be a good ecu if I wanna keep going crazy on power upgrades lol on the dim sim plenium but I hate the the look off the stock one it makes me wanna close the bonnet lol
Hating the look of the plenum isn't enough of a reason to change it and lose torque.....
stock one looks awesome.. here's my engine bay
halthech will grow with you.
Last my engine was running, I was at 445rwkw.
And there are plenty more with higher power then me.
As i said though, go the platinum pro plug in.
Seems to have a better feature set.
The sport 1000 doesn't have support for more then 4 coils from memory.
Think i shall be seeing JEM for the Halteck on myS2 R33 with my hiflow i recently got. Already saw a 49kw increase atw with the stock ecu and an avcr controller on the same 10psi that the stock turbo was running. The halteck can also support the very sexy looking racepack dash later on ;)
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
