Hey All,
Up for sale is my Tomei Forged 1998 Series 1 Nissan Stagea in KR4 Silver. I am the first and only Australian owner after having imported it through a broker in 2007.
The car was stock as a rock when it first came over, apart from some 17" TE37s and a Blitz Nur Spec Exhaust. Over the years I progressively modified it until it has become the monster it is today. Unfortunately for me, a very recent change in circumstances has meant that my partner and I only have room for one car, and so mine must go. As it stands I put the car in storage as of yesterday, and it won't be coming out until it has sold.
I have $30929.01 of new parts purchasing and installation receipts on hand from the last 14 months. Around $25000 of that cost was absorbed by a complete engine rebuild with Tomei components which is now just 4000 kms old. Over the 7 year ownership period I have spent over $50000 in modifications on this car, I built it to be a tough street sleeper, and future-proofed it to easily withstand over 450kW atw if and when I decided to upgrade. The bottom end consists of Tomei Pistons, Tomei Rods, Tomei Oil Pump with Jun Extended Crank Collar, N1 Water Pump, ACL Race Bearings and ARP Main Studs, Head Studs and Rod Bolts teamed with a Tomei Sump Baffle and an aftermarket Harmonic Balancer. The fully reconditioned head features Tomei Poncams and Supertech Valve Springs with Titanium Retainers and all the appropriate Oil Drain Mods. Hooked up to an externally gated GT3076R and running E85 through ID1000s, this engine has revved as high as 9600+ RPM on the dyno and 8000 RPM on the Street. The Tomei oversized Forged Pistons take the capacity up to 2556cc and the car runs 320wkw and 858Nm of torque after the first post run-in tune was completed 500 kms ago.
I am frustrated to have to let the car go at this point, but my loss is your gain.
Please take some time to have a look through the modification list, general information and pictures below.
Modifications:
Engine:
  • Garret GT3076R, 0.82 Rear
  • Tial 44mm External Wastegate
  • AM Performance Low Mount Exhaust Manifold
  • Tomei Forged Pistons
  • Tomei Forged Rods
  • Tomei Oil Pump
  • Jun Extended Crank Collar
  • Tomei Sump Baffle
  • Genuine N1 Water Pump
  • ACL Race Series Bearings
  • ARP Main Studs, Head Studs and Rod Bolts
  • Aftermarket Harmonic Balancer (The brand escapes me, I will confirm with Jaustech if interested)
  • Block/Crank Crack Tested, Linished, Decked etc.
  • Tomei 256 Poncams
  • Supertech Valve springs with Titanium Retainers
  • Full Head Recondition with Mild Porting
  • Oil Control Mods
  • Shaved Deck
  • Injector Dynamics ID1000's
  • Turbosmart Low Profile Fuel Rail
  • Turbosmart External Adjustable Fuels Pressure Regulator
  • Turbosmart Fuel Pressure Guage
  • Walbro E85 In-tank Fuel Pump
  • Splitfire Coilpacks
  • AM Performance Metal Intake Pipe
  • Z32 Airflow Meter
  • Apexi Pod Filter
  • Cooling Pro Return Flow Intercooler
  • AM Performance Split Dump Pipe
  • Venom 5" High Flow Metal Cat
  • Blitz Nur Spec Cat-back Exhaust
  • Greddy Catch Can with Speedflow Fittings and Braided Hoses
  • Setrab 19 Row Oil Cooler with Speedflow Fittings and Braided Hoses
  • Radiator fully reconditioned
  • R34 GT-T Nistuned ECU
  • Blitz SBC ID III Dual Solenoid Boost Controller
  • R33 GT-R Pull Type Gearbox
  • Extreme Ceramic Cushion Button Single Plate Clutch
  • Brand New Belts, Pulleys and Tensioners throughout
Exterior and Suspension:
  • Masa Motorsports Front Bar
  • Masa Motorsports Side Skirts
  • Dayz Rear Bar Garnish
  • Series 2 Rear Lights
  • Series 2 Front Fog Lights
  • Nismo Clear Side Indicators
  • Volk Rays Gram Lights 57DR in Black, 18 x 9.5 +22
  • Federal 595RS-R Semi-Slicks 235/35/18
  • Kics Legdura Black Wheel Nuts with Lock Nuts
  • R33 GTS-T Front and Rear Calliper and Disc Upgrade
  • Racing Logic Height, Damper and Rebound Adjustable Coilovers
  • GK Tech Billet Rear Camber Adjustable Arms
  • GK Tech Billet Rear Toe Adjustable Arms
Interior and Sound:
  • Full Black Leather Interior
  • Series 3 R33 GT-R Drivers Seat
  • Series 2 Stagea Manual Centre Console
  • Nismo 5MT GT500 Black Gearknob
  • R34 GT-R Nur-Spec Footrest and Pedals
  • Greddy Infomometer Touch
  • Parrot Bluetooth Handsfree
  • Pioneer DEX-P99RS ($1599 RRP)
  • JL Audio C5 650 Splits, (Front Speakers, $699 a pair JB HIFI)
  • Alpine Type-R 6.5" Splits (Rear Fill)
  • JL Audio 13W7 Subwoofer (Hard to buy, I paid $2500 in a box for mine brand new)
  • 1 x Alpine 4 Channel Amplifier
  • 1 x Kenwood 4 Channel Amplifier
  • 1 x DLS Monoblock 1000w RMS Amplifier
  • Optima Yellow Top Deep Cycle Battery
Other Notable Features:
  • Twin Sunroof
  • Cargo Blind
  • Cargo Mat
  • Factory Dayz Edition
Spares (These will go with the car if you choose to take them):
  • Volk Rays TE37s in Black, 17 x 8 +45 (need Tyres, good for minimising attention if need be)
  • Series 3 R33 GT-R Front Passenger Seat (Immaculate condition)
  • Leather Drivers Seat
  • Nismo GMAX II Twin Plate Clutch, 20% worn, 80% left (Needs release bearing)
As mentioned, the fresh engine has 4000kms on it. Almost every mechanical item has been replaced or reconditioned, I intended to drop something like a PT6266 on this in the future so I didn't cut any corners on the build. Make no mistake, this engine is a street monster and will happily rev beyond 8000 RPM. The Greddy Infomometer clearly shows the current Max RPM reached as being over 9600 RPM, and the thing sounds awesome up top :) I have dyno sheets for the 3 tunes I have had done since the build was completed. Initial run-in (0kms - 289kW @ 15psi), second run-in (1000kms - 309kW @ 19psi dropping to 17psi) and post run-in (3500kms, 320kW @ 23psi dropping to 17psi). The engine is laughing at this power level, but the turbo has predictably reached it's peak. All dyno runs were performed with Semi-Slicks on the Jaustech dyno, renowned as 'The Heartbreaker'. I simply can not stress how awesome this engine is and sounds, it was built for 450+kW with a bigger turbo and just begs for more :) If you have any questions about the build then please don't hesitate to contact me, and I'm sure the guys from Jaustech won't mind helping out with info either.
The gearbox and transfer case were pulled down last week and inspected and are in fantastic condition.
The engine runs on E85, and I will include two 20L Jerry Cans (empty) with the sale.
The chassis has 130000kms on it, not a problem to speak of. I replaced the front CV joints last year (right and left entire assembly) as the front left was showing wear. I upgraded the rear differential last week to a stronger viscous LSD. Everything else is in good working order.
Aesthetically, the car is in great condition for it's age. It does have the typical Stagea rust under the mirrors, and the front bar has damage on the lower lip. Whatever price the car is sold for I will refund $500 dollars to go toward the front bar repair. There is no point doing it now in case it gets damaged again in the meantime. I have always taken care of it, washed and polished on a regular basis, and it has managed to stay out of trouble in terms of accidents. It has a bit of normal wear and tear, minor scratches barely noticeable to the eye and a few small blemishes inside the vehicle, but nothing out of the ordinary. I will let the pictures speak for themselves :)
The handbrake mount will need to be addressed (a quick spot weld) as it has weakened over time, but the operation of the handbrake is not effected. There are some light scratches on the manual console trim, they were on it when purchased second-hand.
The car is currently registered until July and has never been defected. Most of my modifications in the engine bay have been painted black for the sake of stealth to help the car stay on the road, and so far I haven't had a problem. This really is a lethal street weapon, and makes a lot of noise when opened up :D
I am more than happy to provide receipts for the eventual buyer if need be. I work Fly In/Fly/Out so I can be hard to get a hold of, sms or email works best as sometimes I will be out of phone range for periods of time. If you are serious about the car I can organise a family member to meet for a viewing. There will be no test drives without a cash deposit of $5K, but I am ,of course, more than happy to take you for a spin.
I am after $22,000 ONO for this Tomei Built beast, I can assure you that it's worth every penny :)
Please have a look at the pictures below and let me know what you think!
Cheers,
harts.
0423947424
[email protected]
Edited by stageaharts
Ahh there is a few others knocking on the door :) ! Just need the motivation and time to put my new engine in . The stock 25 in there just won't die lol and I hate taking good engines out :)
Somebody buy this cheap for what's done will eat 260 rs for lunch
  • Like 1
I had some brand new rose joints sitting around for the rear GK Tech adjustable camber and toe arms, so I had them fitted :)
  • 3 weeks later...
  • 1 month later...
PRICE DROP BELOW:
I have got a couple of weeks off of work for a change, so I am going to give the car some attention. I took the car for a quick spin again today to give her another break from storage. Fresh ethanol and fluids, a very entertaining drive. I will try and get some more video up of the car running over the next couple of days.
I took a photo of the Greddy Infomometer touch whilst I was there, as you will see in the picture, it indicates maximum RPM reached: 9662 RPM.
It's a monster :D
Also, as indicated by the pictures in my original post, the car has Genuine Carbon Type Ganador Electric Mirrors, I forgot to list that. The car has 3 Months rego on it.
Price drop to $19,900 ONO.
Honestly, you couldn't build the engine for anywhere near that price, the person that buys this car will be getting the bargain of a lifetime :D
(btw the second photo is the same, just a modified colour profile to make it easier to see the numbers)
  • 4 weeks later...
The unicorn has been on Gumtree for a few weeks now and I have received some decent, bad and hilarious offers, including a sweet 350wkw wrx swap and one guy asking me to loan him the money to buy the car. Man I love Gumtree lol.
Car is still for sale, and I would love to free up some cash, so send me an offer... it can't be any worse than the guy without any cash :D
  • 2 months later...
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
