Hey Guys parting my r34 - 4 Door + Some S13 Gear Sr20det
Pretty much Complete car parting. Let me know what your chasing and ill see if i have it.
Zeal Coilovers - 550
Lock Setup -
R33 Front Cross Member Rack moved Forward has superpro bushes, Cut n Shut Knuckles + Extended Lcas etc Can included Rack + ends Gktech Castor rods etc. (Casey) - 550.00
43 mm Koyo Copper Core Gtr Radiator ( Mint Condition) - 320
Gtr Fmic ( Also Mint) with one piece piping to suit neo - 350.00
R33 Gtr Diff with half shafts etc - 550
Exedy Super Heavy Duty Clutch ( Push type) 350.00
Gktech Camber Arms V2 - 110
Gktech Rear Toe Arms- 110 ( Both brand New Been test Fitted)
R34 - 4 Door 1 peice 3 inch Stainless exhaust 350.00
r34/ 4 door Manual Conversion everything bar clutch line and gearbox (Clutch pedal, Clutch Master, Cross member, tailshaft, Manual Gear boot surround) 500.00
R34 Bonnet Needs Paint - 220
R34 Passenger Guard - 120 ( Includes Drivers with dent.
R34 Rear Lights 120.00
R34 Manual Gear Surround 130.00 Not best Condition but painted would be mint, Leather Boot is clean.
R34 Front Seats 200
R34 Rear Seats 120.00
R34 Dash etc - 100
R34 Cluster 120
Or all interiior including all belts plastics rear plastics carpets etc - 800
Rb25de + t Neo Motor - (Has Turbo Drain to Sump Det Ecu, afm, lume, injectors, and intake)
Metal head gasket
Gates timing belt
Gates water pump
New timing belt tensioners
Nismo thermostat
N1 oil pump
Rebuilt rb25neo turbo
New turbo lines
New oil pressure sender
1800.00
Also have some other stuff lying around
Rb25det s1/2 Tomie Type A heavy duty Valve Springs in box Brand New 220.00
Works Rezax 17x9 4x114.3 Refurbished powdercoated Centres Polished lips - New tread 17*9 + 17*8.5 - 1500 ono
Defi Control box with boost Solenoid - 110.00
Ls1 Coil Packs 150.00
S13 J's Headlight Covers _ Standard Fix your broken ones - $100.00
S13 Tailshaft bracket - 20.00
Sr20det Gear box x 2 both Reconditioned by professional - 400 with shifter 350 without.
All Stuffs Located north Bris
Bribie island
Brayden
0405639821
https://www.sau.com.au/forums/topic/443630-r34-4-door-part-s13-sr-gear/
