Is it normal to smell a bit of coolant from the radiator cap,
I think it is almost new as it was replaced on my last service by my mechanic 5,000 km ago.
Does the radiator cap vent a small amount of pressure to the atmosphere or should i have no smell whatsoever and my cap is not sealing properly.
Also when i check inside my overflow bottle after the car has warmed up i see some residual bubbles around the edges of the overflow bottle, not bubbling, just some bubbles floating on top in small clusters.
Is this just a normal reaction to the coolant expanding and being sloshed around or do i have air entering my system and being pushed out.
I just want to make sure i don't have an issue. the colour of the coolant is bright green and car is not overheating.
if anyone has looked inside their overflow and saw small bubbles floating around the top could you reply,
Would be good to check.
Car is an R34 GTT
Thanks
Edited by Bugzs15
https://www.sau.com.au/forums/topic/443634-coolant-question/
get your car up to full operating temp such as after a 20min + drive. leave the car idling, get out and go and listen to the radiator n motor. if you hear bubbling noises- not good. if bubbles are coming out into the overflow bottle, also not the best.
But likely that the mechanic just didn't bleed the system well if you say it has been done recently. if so then search SAU how to properly bleed that air from an RB25.
yes, its likely you will smell radiator fluid as they would have spilled some doing the fluid change.
Did that, and no bubbles :) in overflow, so hopefully just some air getting into the system and being pushed out when car is warming up.
I have been losing around 100ml of fluid every 5000km but cant find the leak anywhere so will just keep an eye on it.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
    • Just buy a bunch of covers off aliexpress, they're like $5 each. Rattle-can them and stick them on as needed/fly off.
