Hey guys,
Up for sale is my 98 R33 Gtst 40th Ann. $7500 ono
178XXXkms
Rego due end of August (Around the 25th)
Car is pretty well kept, went from being my weekender to my daily (bought a Cruze 1.6t as a daily, hate it). The car is mechanically perfect, hasn't skipped a beat since I've owned it. Gearbox is smooth, previous owner stated the clutch was replaced a bit over 2 years ago (factory Nissan) so its fairly meaty. A/c works a treat hot or cold. Being my second Skyline (first was a 32gtst, boy was that trouble), the first thing I replaced was the IACV with a genuine part from Nissan in Chicago (only replaced due to paranoia). Car came with a Blitz turbo timer and immobiliser (mongoose, according to the sticker),
Whats been added;
Turbo back JJR stainless exhaust, x-force hiflo cat 3in to 3.5in (have Trust Cat Back 3in, will go with the car, much quieter)
GFB Geforce 2 EBC (Set at 7 & 10psi)
Cooling Pro Return Flow FMIC
Apexi Pod Filter
Replaced the head deck with a JVC double din but its nothing really noteworthy, just put it in as the previous owner had a Kenwood unit that was tuned to Jap Freq. (I am the second owner in Aus), also replaced the lowered suspension that was installed to raise it to standard height. Would love to have had it tuned, just never got around to doing it, and im sure the car would benefit from it.
The bad.
About a month ago, my car coped a knock whilst parked at the shops (Penrith Plaza), as shown in the attached photo's. Car will need 4 new tyres, however if sold for what its listed I will be replacing them.
Would love to keep it, however I'm planning on buying a boat, and to do that I need both my cars gone (tow appropriate vehicle needed) for space and useability
Call or Text 0429477393. (Would prefer a text as I'm a shift worker, but will make the effort to answer regardless)
Cheers
Kez
post-124417-0-49661600-1401066786_thumb.jpgpost-124417-0-32314000-1401066813_thumb.jpgpost-124417-0-30781700-1401068668_thumb.jpgpost-124417-0-71615300-1401068688_thumb.jpgpost-124417-0-92982900-1401068717_thumb.jpgpost-124417-0-52833800-1401068743_thumb.jpgpost-124417-0-57043800-1401068770_thumb.jpgpost-124417-0-73427600-1401068801_thumb.jpgpost-124417-0-90819900-1401068821_thumb.jpgpost-124417-0-03480200-1401068843_thumb.jpgpost-124417-0-20667100-1401068863_thumb.jpgpost-124417-0-73968200-1401068882_thumb.jpgpost-124417-0-47080200-1401068897_thumb.jpg
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
