Regretful sale but can't afford the time & money to enjoy it with my other hobbies.
Car is in storage and not fussed if it sells so genuine interested buyers only.
Car has had $40,000 and countless hours invested into it so feel free to build your own if the price seems high.
Car has featured in several magazines and won several trophies.
Always used top shelf fluids and regular changes each drive
Car is on E85 E-Flex and always maintained/taken precautions when in storage.
Car is registered in SA, can help with arrangements for interstate buyer
NO SWAPS although a spastic GTR might sway me
Nissan 180sx
RB25DET Series 2
Garrett GTX3076R Tial Stainless Turbine housing 0.82A/R
Turbo Blanket
Steam Pipe Merge Collector Manifold / Ceramic Coated
Tial 44mm MVR Wastegate
Stainless Teflon Turbo Oil/Water Lines
Fireproof Heat Sleeving on Turbo Oil & Water Lines
Stainless Dump Pipe / Interchangable Screamer Pipe
Stainless 3" Exhaust With Twin tips
Stainless Lobster Welded Intercooler Piping With Tbolt Clamps throughout
Custom Alloy Catch Can & Speedflow lines
Front Mount Intercooler
Greddy Foward Facing Intake Plenum
Nissan Q45 3.5inch Throttle body
Bosch 1000cc EV14 Injectors
Alloy Fuel Rail
3 Walbro Fuel Pumps 1 Intank / 2 External
Custom 3 Litre Alloy Surge tank
Turbosmart Fuel Pressure regualtor FPR1200
Turbosmart Fuel Pressure Gauge
Stainless Braided Teflon Fuel Lines in Engine Bay
Nistune z32 ECU W/VCT
Z32 Airflow Meter on pressure side
Splitfire Coilpacks
Turbosmart E-boost Street Boost Controller
Drift Electric Fan Controller
Davies Craig Twin 14" Fans
Saber Alloy Radiator
Greddy Radiator Cap
Custom Alloy Overflow Tank
Carbon Cooling Panel
Greddy Oil Cooler & Filter Relocator
Stainless Pod filter
Custom painted House of colour Marbalised Rocker covers
Optima Yellow Top Battery(Boot)
Velo Tow Strap
Remote Start Alarm and Battery Isolator switch
Speedo and Tacho adjusters/correctors
Driveline:
RB25 5spd Manual Gearbox
Custom Gear box mount
NPC Carbonetic 1600kg Puk Clutch
Custom 1 piece tailshaft
R33 Skyline Brakes with DBA4000 t3 Rotors and Bendix pads
R33 Brake Booster
5 Stud Conversion
Nismo 2 way Diff
Whiteline Cradle Pineapples
Exterior:
Millenium Jade Paint 2 Toned with Black Top
Vertex Front Bar
Vertex Side Skirts
Vertex Rear Bar
Origin 40mm Front Fenders
Flaired Quater Panels
Origin Carbon Spolier
Origin Carbon Roof Spoiler
Dmax Tint Tail Lights
Suspension:
ISC Coilovers 8 & 10 kg
Tein Adjustable Caster Arms
Whitleine Adjustable Swaybars
Whiteline Camber Arms
ISC Toe Arms
Front & Rear Strut Braces
Interior:
OMP Deep Dish S/wheel
Autometer Gauges Oil Pressure/Oil Temp/Water Temp/Boost
Bride Fixed back seats on ultra low rails
Bride Trimmed Door Cards
Bride Trimmed Glovebox
Nismo Labelled Floor Mats
Rims:
URAS Excol 9.5" Front & Back
Toyo R888 Semi slick & Federal 595 Tyres
Price $23,500
Contact Via PM
post-44040-0-58985000-1401103199_thumb.jpgpost-44040-0-39128200-1401103211_thumb.jpgpost-44040-0-79419000-1401103229_thumb.jpgpost-44040-0-73471900-1401103246_thumb.jpgpost-44040-0-90524800-1401103257_thumb.jpgpost-44040-0-35495400-1401103269_thumb.jpg
https://www.sau.com.au/forums/topic/443668-180sx-rb25-gtx3076-360kw-sa/
  • 1 month later...
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
