Logitech G27 + Gt5 / Gt6 Drifting
Trex
 Share
Had another go tonight with a standard 370z.
I can come into a corner at the top of third, feint into a slide then put about 1/2-3/4 throttle down. I can link an S. But I'm only countering 200 degrees.
60% of the time, it works everytime.
  • 5 months later...
  • 4 months later...
Ah OK well first things First have you set your wheel up correctly and you MUST run the Profiler, that is an absolute must to have ANY decent control.
Secondly what Simulation and or Mod for that sim are you using ?
IF you using a PS3 or console forget the above as this is then not applicable.
If you want to set your wheel up in a PC situation then I can help you in that regard.
Ended up taking power steering off so it's a lot heavier and has heaps of force feedback. But I usually just drive the calsonic 32, works well and is fun to drive. Started competing in rooz in gt6 and I can't believe some lap times people are getting
 Share
