log in Posted May 29, 2014 Share Posted May 29, 2014 Alright i couldnt find much from searching, but im about to move to a external fuel pump setup with surge tank to replace my single walbro 400lph pump. I'm looking at a fuel system capable of supporting 650-700rwhp on e85. My idea is to use 2x044's pumping into the standard feed and return lines, then have -6 feeds from the end of the hard lines to each end of the fuel rail and have a additional -8 return line to the surge tank. I'm interested to know what others have done with the return line from the surge tank to the main tank, is it worth upgrading to -8 hose with a bulkhead fitting on the tank to lower the restriction of returning fuel or just use an adapter into the factory return line from surge tank? also my fuel rail has a -6 return to the fpr, is it worth modifying to -8 or is it all overkill Also if i did use a bulkhead fitting whats the best option with the jet pump, is it necessary as it looks to be quite a restriction to a higher capacity fuel system Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/ Share on other sites More sharing options...
Piggaz Posted May 29, 2014 Share Posted May 29, 2014 I'm running a very similar setup. Lift pump into a 5 litre surge tank, twin 044's into standard feed and return, into fuel rails, -8 out of the middle to reg, -8 back to surge, -6 back to tank using the standard fitting. Absolutely no issue. I have a fuel pressure gauge which reads from the FPR. All seems happy. Has been like that for almost 4 years. Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7297517 Share on other sites More sharing options...
ido09s Posted May 29, 2014 Share Posted May 29, 2014 I went slightly different and fitted a pair of -6 lines from the two 044 pumps to the fuel rail,-6 out of the centre of the rail to the FPR, and the largest standard line as the return to the surge. I have contemplated a fuel cooler as it does get warm, i have a spare -10 GReddy oil cooler core, but havent got around to it. Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7297640 Share on other sites More sharing options...
log in Posted May 29, 2014 Author Share Posted May 29, 2014 Cheers for the replies guys, what are you using for lift pumps? The walbro 400 is gonna be massive overkill for just feeding the surge tank, should I go to a 255 or 040? Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7297654 Share on other sites More sharing options...
Piggaz Posted May 29, 2014 Share Posted May 29, 2014 I've used a Nismo and currently an 044. Both did the same job. I suppose, as long as you have an overflow from the surge tank back into the main tank, you can't (within reason) bugger that up. Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7297680 Share on other sites More sharing options...
KiwiRS4T Posted May 29, 2014 Share Posted May 29, 2014 Is it a track only car or for street use as well? I have a Walbro lift pump and one 044 from the surge tank but its as loud as and I wouldn't want two of them. If I were doing it again (and if I were you) I would use one (or two) of the more modern pumps such as the latest Walbro Or DW pumps. Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7297809 Share on other sites More sharing options...
log in Posted May 30, 2014 Author Share Posted May 30, 2014 Street mostly, did anyone take the jet pump off or are they not causing to much restrictions Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7298462 Share on other sites More sharing options...
scotty nm35 Posted May 30, 2014 Share Posted May 30, 2014 I would have thought you could make that power with what you have. The 460L e85 pumps flow 450ish kw at 13.8v, much more if you bump the voltage up. The stock lines would have done the job realistically. If you need a surge tank for the track that's a different story, just make sure there is no raw alloy in the system, it does eventually corrode. 6an return should be fine. 044's are noisy old designs. There are much better, modern pumps up to the task for external duties when the Walbro can't keep up. Something with PWM ecu speed control built in is probably your best bet. Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7298475 Share on other sites More sharing options...
Piggaz Posted May 30, 2014 Share Posted May 30, 2014 044's are noisy old designs. They really are not that bad if you rubber mount them. But yes, there are quieter pumps out there. Link to comment https://www.sau.com.au/forums/topic/443756-fuel-system-setup-and-jet-pump/#findComment-7298486 Share on other sites More sharing options...
