Hey mate,
I've done a little research myself couldn't find much on the lock bars although I hear the z32 may be the right size.
However in all my research I think the best solution would be to fit a Driftworks HICAS removal kit which is a universal mount for all HICAS cars
Take a look you'll see how instead of putting a lock bar in the middle it instead removes the bar all together and uses it's own brackets, it's a little more expensive than a lock bar but seems to be a better solution, lighter weight as well.
http://www.driftworks.com/driftworks-total-hicas-eliminator-kit-for-nissan.html
I do not have one of these kits so if it works with the C34 rs4s I can't confirm 100% but from the looks of how the eliminator kit works and what I've seen under my own car it looks like it would.
This is potentially something I will be doing to my rs4s soon so if I do I will keep you informed as to how it goes.
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
