recently took my car to the tracks and noticed some issues which were not there when it was tuned about a year ago (not putting the blame on anyone here)
at idle, when you tap the throttle, it feels like the revs drop momentarily. Even when you rev the car in neutral, it feels like there is hesitation below the revs pick up. any idea what this is?
also at wide open throttle (WOT) the top of 3 gear is splattering. is this lack of spark? i have a big fuel system in the car and on the dyno it was fine, but im sure real life situations are different to dyno.
and last thing is at wakefield, as i come in fast to a corner and brake (turn 2, fish hook and last corner) the car doesn't rev or do anything! it drops to neautral for about 2-4seconds then picks back up again. I've tried to rev match and downshift but nothing worked! Car drives on the street fine but this is concerning me.
Is it a Tune? Spark? Fuel?
https://www.sau.com.au/forums/topic/443762-gtr-issue/
Sounds like fuel surge on corners , but u have bit fuel system , changed filter in last year? I'd be checking fuel pressure and also all fuel related electrical connections , sputtering up top happened to me recently and was a boost leak I didn't know about , if all if above ok I'd look at earthing coils directly before looking at tune,but you could contact your tuner usually they are more than happy to hp if they are any good lol
https://www.sau.com.au/forums/topic/443762-gtr-issue/#findComment-7297521
Simplest thing to start with for the 3rd gear splatter is to pull the plugs and take a look. Change them anyway if they're old. Don't run a wider gap.
Also, tunes don't last forever because all the components that produce power wear/get dirty etc and don't behave exactly like they did when the tune was done.
Agree that fuel surge is the last issue. As soon as that happens head off the track and back to Goulburn to fill up again, or take spare fuel and save the trip. You'll find it starts at about the same fuel tank level each time.
https://www.sau.com.au/forums/topic/443762-gtr-issue/#findComment-7297613
i'm gonna make some guesses here.... you need to do this
i did this on my wifes GTR that had a missfire when up it in third. the second part might be that your tuner may not have done your accelerator correction, or it could be your TPS. make sure your tps is reading the correct voltage at idle i think its 0.45v-0.55v at throttle closed position, the voltage should increase to somewhere between 3-5v at WOT. you don't need to do this with the car going but just the ignition turned on.
whats your ECU ? can you datalog?
https://www.sau.com.au/forums/topic/443762-gtr-issue/#findComment-7297706
shall be cleaning the fuel filters out this coming week. plugs checked out ok and did a quick compression test as well and engine seems good. strange why it would be spluttering down the straight if it was surging as that is what i would expect from cornering
fuel system consists of a Weldon 2015A fuel pump, Earls billet fuel filters, -8 lines to the surge tank, -8 hose all the way up to the engine then splitting up to 2x -6 at the fuel rail
https://www.sau.com.au/forums/topic/443762-gtr-issue/#findComment-7298613
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
