Picked up a Quafie/Trust 6 speed dog box to use with our GTR build and i am thinking of changing the input shaft to something stronger knowing that its a weak link with drag racing.
Ive heard that the shaft sizes can be increased to Chev size and spline, we can get Jim Berry to change our clutch center to suit.
Interested to know of any recommendations for who to see for a larger/stronger billet input shaft to get made up.
Thanks in advance.
https://www.sau.com.au/forums/topic/443764-larger-billet-input-shaft/
Another thing to look at is cryo treating. I am the world's biggest sceptic with regard to cryo. Having done materials science and all that jazz at uni, I know what you have to do to make atoms move around and re-arrange themselves in metal - hence why heat treatment involves getting stuff hot. Cooling stuff down to try to achieve these effects seems counter-intuitive. The cooler you make a metal, the less mobile the atoms in the crystal structure are.
But.....business across the road from me is an automatic transmission workshop that builds a lot of autos for a lot of serious drag cars. They got sick of Ford input shafts breaking in a few cars that they deal with and did some cryo treated ones. Gone from breaking them nearly every time out on a couple of cars to "not broken one since".
Anecdotal evidence, sure. But it lines up with a lot of other similar stories. They can't all be placebo now can they?
  • Like 1
PPG do a billet mainshaft with the Chevy splines, but obviously won't suit your 6 speed. Have you contacted Quaife to see what they have? We shot peen and Isotropic Superfinish (REM) components to improve fatigue resistance, and may be a good solution whether you stick with the standard shaft or get one fabricated. If you want more info on the technology have a look at our website: www.neategearboxes.com.au
  • Like 1
I will be sending Quaife a email this weekend to see what they say, somehow i dont think they will have it but i will try.
My thoughts on the 2 suggestions above, which have already run through my head before i posted....
Cryo treatment.
My thoughts are that any strengthening of the input shaft steel metallurgy will only make it more brittle and prone to crack more easily.
Possibly with a auto where the shock loads are less (as explained by GTSboy on autos) it may be a good thing, however i am suspicious to how well it would hold up in a 600Kw at all 4, 4WD manual application with a high clamp load clutch cover in a drag racing application with sticky rubber.
Making the metal stronger in my eyes, makes it more brittle, however my level of expertise in this area is old school self taught, happy to listen to corrections to my train of thoughts in this matter, my mind is open to suggestions (and education by those who know more).
Shot peening and stress relieving......there's something we use to do before after market rods were around. :)
Again, a surface depth treatment, better than standard for sure, however i dont believe it will be enough for our application.
Id be more inclined to shot peen as it improves the fatigue cracking resistance over Cryo which could produce a brittle part.
Im still thinking just getting a larger diameter billet input shaft may be the answer......just a question of where to go to get one made up.
Edited by GTRPSI
I wouldn't consider swapping the input shaft unless it was designed for you gearbox. Tooth profiles would all vary between manufacturers and you could run into a lot of trouble if you got it wrong.
In shot peening's defence, yes it's a surface treatment. So is pretty much any other process we use to make metal stronger and more fatigue resistant. That's because the vast majority of crack formation occurs on the surface. Pretty much every aerospace component is shot peened for this reason and is testament to the process's effectiveness. I'd be surprised if Quaife didn't shot peen gears anyway to be honest.
The REM process can be done to the entire gear set to reduce friction, reduce heat in the oil and so on. If you have a look on the remchem website there are a bunch of SAE papers proving the effectiveness of the process. There are some "stress relieving" characteristics as a result of the process too. A large spline option would be best though.
  • Like 1
Will the OS Giken unit fit your box?
No idea of the OS tooth profile and gear diameter compared to the Quaife one.
At the end of the day i may send it off for shot peening, i might ask Quaife if its already been done to it before i pull it out, good suggestion that it may have already been treated, that didn't cross my mind.
I have sent them a email asking if they make a larger input shaft, just waiting for a answer.
I spent last night researching getting a larger shaft made up, i noticed PPG mentioned they can custom make parts, will see how i go with Quaife first, then contact PPG about sending my sample to them and getting the shaft replicated to suit the Quaife gears in their larger input chev truck shaft size, hopefully they might be able to do it.
Edited by GTRPSI
I chose to leave my input shaft stock size as a bit of a safety measure. If your shockloading the drive train hard enough to break an input shaft, then your putting alot of pressure onto everything down stream. Your also shockloading the tyres...
I figured I would rather an input shaft go than start stripping gears in my ppg gearset, pulling bearings apart, twisting centre plates, body,mounts etc... I also choose to run stock input shafts in the rear for similar reasons.
...saying that, I'm not running 600rwkw yet, but I do use street drag tyres, unsprung multiplate clutch and nitrous.
I guess what I'm trying to say is choose you 'weak link'..... and plenty of very fast GTR's have been racing for alot of years with stock size input shafts.
If your looking for ultimate? then yeah go bigger, but if you go to that extent, I'd be looking at soild mounting almost everything, look at the rear geometry carefully, billet axles/half shafts (they still break) with larger Cv's.....so on and so forth.
..anyway, that's where I got with it.
Cheers
Justin
  • Like 1
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
