1995 R33 GTR
102***km, White
accident damage to drivers side front.
car is standard apart from nismo springs and rpf1 17x9.5.
timing belt done at 100000km
damage- broken castor arm, busted wheel, guard, bonnet, reo, front bar, headlight. SEE PICS
car is still together apart from what was removed for a panel beaters quote.
i am willing to sell the car complete for $9500 this weekend before i remove anything
if it does not sell by saturday i will be keeping brakes, diff, drive shafts, tailshaft, front seats.
phone ROb O439 782 582
located in Wodonga, VIC
Are the pods on the quarter genuine? If so what's your chances of getting them off undamaged?
Cheers, Andrew
part out is a go.
will only remove items for now that will not affect car from driving.
parts not for sale:
wheels, brakes, spare wheel, front seats, rear diff, axels, tail shaft
rear pods - sold
engine, loom, ecu, gearbox - sold pending payment
small items can be posted if organised by buyer. pick up from Wodonga for everything else.
following is sold:
engine, g/box, ecu, loom
seats
brakes, master cylinder
rear diff & axels
boot & wing
interior
intercooler
rear pods
wheels
rear hubs
rear strut brace
still for sale:
suspension with nismo springs $400
clutch pedal $80
side mirrors $30ea
steering wheel $150 ono
radiator $100
front strut brace $120
passenger side guard $80
side skirts $150pair
doors with glass $100ea
std bovs $120
dash cluster (solder joints have all been repaired) $130
center guages $90
pm or call for anything else not listed
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
