Not cause I'm a coastie, but mangrove mountain is a fairly easy course and very relaxed also. Its public and afaik doesnt har a weekend comp, if it does its very small as doent have a big member base. Plus it's a nice drive out there.
I play there every quarter and we rock up with an esky full of beer and the pro shop just laugh at us and hand us the keys to the carts.
That's mad sounds like a great place haha
Ah sunday wallacia golf course you can get on most sundays, glenmore park goodbut lots of water for the less skillfull player to loose plenty of balls in. Dunheavead but probably not till after 12pm. Penrith golf club and theres one near emu plains i cant remember the name of it. Just off the M4 turn off at emu plains.
Leonay Luke? Thanks, for the heads up tho'.
Aaaah WATER!
True Story:- One foursome going around Liverpool Golf Links on a social.
> One guy started off with double/triple bogeys over the first five holes
> Totally demoralised was he
> On the 16th (or so), he came good and won the hole
> He had the "honour"!
> On the next tee, he could see there were still players ahead just beyond the water hazard
> Still nonplussed at the day's debacle, he asked the other three, "Do you think it's OK to hit yet?"
> One of his mates replied, "Sure, there's no-one swimming!"
  • 2 months later...
  • 1 month later...
Riverside Oaks.
One of my clients can get our SAU social group in there. Anyone interested?
This is an International Grade course, once the home of the Australian Open; and about to host the NSW Open.
Cost as a special mates rate would be $80 pp.
Meanwhile DekA Matt is busy organising another special golf day but I think it's best for him to stitch that impressive day out and let us know in due course.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
