Hi out there,
Fairly new to this but in need of some assistance.
My R33 4wd doesn't seem to be engaging the front wheels aka the car drives like a rwd car should. All spin no traction no real pull forward. I have bleed the system in the rear following instructions from this site and all that seems to be working fine. All that seems to be in working order.
I have had the car off the ground and selected a gear and all 4 wheels turn. But give it a bit of curry on the road and no grip, rears just light up.
I have had someone suggest the transfer case might have finally given up and the clutches within are slipping. Is there anything else I can check to help fault find the problem? No lights flash up on the dash, but I haven't looked in the boot to see to see if ecu has any flashes.
Any help would be appreciated, basically car drives like the prop shaft is out.
https://www.sau.com.au/forums/topic/443812-r33-gtr-no-4wd-help/
Realistically seeing as you haven't got a clue,you won't be fixing it yourself.
Take it to someone experienced with gtrs.
Give them money.
Pick up car in working condition.
Boost off into the sunset.
Wait for next problem to arise.
Repeat.
It is easier to play dumb and see if someone who has had a similar problem arise can shed light on the situation. There are no faults appearing in attesa ecu, the pumps work fine and are pressurizing, there is new fluid in system and is bleed correctly. The tires are great and never had a problem before, same with suspension. Car has run 11.2 @ 124mph on exact same set up. When the car is in the air all 4 wheels drive, but on the road drop the clutch and watch only the rears light up. As far as I am aware from everything I have read on here I have tried to eliminate most of the problems. Yet I am not sure as how to test transfer case and know that it is the multi clutch system inside that is letting it down. I was just chasing ideas that I may have missed by people adding suggestions. My main suspicion was the transfer case but wanted any light shed before I put the car on the hoist and remove the box.
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
