My car's been sleeping in a paddock for about 18 months, and when it came back the oil temp and water temp gauges both are not working.
Now the checking for 12v power, earth and 12v lights stuff I can do, but I want to confirm how the sender wiring works.
The water temp gauge just taps into the ECU water temp sender. Am I correct assuming that the sender works by showing a resistance compared to earth? Am I also right saying if I measured voltage compared to a good 12v source it would show something like a couple of volts when cold and closer to 12v when hot (depending on the exact calibration of the sender)? If not, how can I get a basic indication that the sender is connected properly and sending a reading to the gauge?
Same question for the oil temp gauge but it has 2 wires to the sender. Will one be earth (from the gauge) and the other the return signal? If I measure the resistance between the 2 it would decrease as the oil gets hotter?
https://www.sau.com.au/forums/topic/443820-troubleshooting-gauges/
Actually I think the gtr workshop manual answers that question, in the water temp troubleshooting section it says to measure voltage between the sender output (ecu 28) and ground, and I should get:
20o = 3v
80o = 1v
Both will be NTC thermisters, or negative temperature co-efficient. Which basically means when it is cold, it will read a high resistance, and as the temperature rises, the resistance will drop. Easiest way to check these would be consulting the workshop manual for values dependent on temperature, and using a multimetre between earth and signal and reading the resistance. If the resistance drops and is within range, the sender isn't the issue. To check the gauge, either use a gauge tester, or earth the signal wire breifly and the gauge should move to hot. (as earthing it will give very little resistance to ground, simulating a hot reading)
Even though it is a sensor, not a sender (difference being 3 wires, not 2) it will still be changing resistance, only the ECU will be interpreting these values as a voltage, not a resistance, but the test should still be the same.
    • Got my R34 gearbox around 4-5 weeks ago. Came into some extra $$ recently and after I cleaned the mess off the notes, I thought, might as well buy that R34 box I've been pondering.  In that time I've pulled the engine out, replaced rod and mains bearings, done a few other engine things that are much easier with the engina out eg PRP oil pump upgrade, replacing wastegate coolant lines, installing Turbosmartass turbo oil pressure reg, made some mounting brackets for some of my mods that are "hard to reach", converted the R34 box to R33, put the engine and new gearbox back in the car. Plus cleaning ...Oh my god so much cleaning when doing such a project. Yep I'm a busy bee, buzz buzz. As part of the gearbox project, researched posts and found this thread (In which i nailed it for the OP), hence the post here # logical thinking.. Not all about you old boy, SOrrryyy. Dare I ask,  how's yours going ,> Or you got it done yet, and if so why didn't you post any of the tips I posted to help other members? ???
    • Seems to be the case mate , still an OK price for a grey import.
    • I’m interested in the carbon diffuser fins and Toshiba MFD screen replacement if they’re still available.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 🙂
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
