My car's been sleeping in a paddock for about 18 months, and when it came back the oil temp and water temp gauges both are not working.
Now the checking for 12v power, earth and 12v lights stuff I can do, but I want to confirm how the sender wiring works.
The water temp gauge just taps into the ECU water temp sender. Am I correct assuming that the sender works by showing a resistance compared to earth? Am I also right saying if I measured voltage compared to a good 12v source it would show something like a couple of volts when cold and closer to 12v when hot (depending on the exact calibration of the sender)? If not, how can I get a basic indication that the sender is connected properly and sending a reading to the gauge?
Same question for the oil temp gauge but it has 2 wires to the sender. Will one be earth (from the gauge) and the other the return signal? If I measure the resistance between the 2 it would decrease as the oil gets hotter?
https://www.sau.com.au/forums/topic/443820-troubleshooting-gauges/
Actually I think the gtr workshop manual answers that question, in the water temp troubleshooting section it says to measure voltage between the sender output (ecu 28) and ground, and I should get:
20o = 3v
80o = 1v
Both will be NTC thermisters, or negative temperature co-efficient. Which basically means when it is cold, it will read a high resistance, and as the temperature rises, the resistance will drop. Easiest way to check these would be consulting the workshop manual for values dependent on temperature, and using a multimetre between earth and signal and reading the resistance. If the resistance drops and is within range, the sender isn't the issue. To check the gauge, either use a gauge tester, or earth the signal wire breifly and the gauge should move to hot. (as earthing it will give very little resistance to ground, simulating a hot reading)
Even though it is a sensor, not a sender (difference being 3 wires, not 2) it will still be changing resistance, only the ECU will be interpreting these values as a voltage, not a resistance, but the test should still be the same.
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
