  • Replies 82
So if the Stock GTR cams work in the RB20 could you use aftermarkets? Like HKS Step 1's? HKS web page with cam specs translated into egrish
R32,33 IN 264 degrees 8.7 110 degrees
EX 272 degrees 8.7 113 degrees
Rb20 IN 264 degrees 9.0 110 degrees
EX 264 degrees 9.0 115 degrees :)
        EX 264 degrees  9.0  115 degrees  ;)
i don't see why you couldn't? i think cams are generally for 'rb' engines so as to work in either rb20/25/26
just be wary that after a certain amount of lift, the rb20 head needs to be modified i think to accomodate the installation. can someone clarify this further?
The GTR cams are a mild upgrade that don't cost too much. Good bang for your buck. :cheers:
When you get into aftermarket cams the costs are substantially higher. Not just for cams themsleves, but valve springs, convert solid to hydraulic followers, machine head for lobe clearance etc. Suddenly it is not such good value as for the same money you can buy more effective upgrades.
Plus an RB20 is 2 litres and the larger cams you put in the more rev happy you needo be
The workshop where my car is claims the RB26 cams in Rb20 have been tried, and the result is ordinary... ie you lose power down low, and any top end increase seen with these cams isnt worth the trade off...not the expected result from a mild lift and duration increase. Also sighted concern over a solid lifter cam being used with hydraulic lifters.
So since they have my car, and they are advising against leaving the cams in, well im going to get them to take them out...for no other reason then if my engine dies after the tune, then i hadnt gone against their advice and they can be held more accountable.
Out of interest does anyone know if cams for sold lifter engines have a more aggressive cam lobe, whereby accelerating the valves open / closed any quicker then used for hydraulics...still having the same duration and total lift, but different gradient to fully open?
Can anyone verify that coz if i do the GTR cams I don't want to lose anymore down low power/torque :wassup:
Good point,can that be promblematic later down the track?
Well in my case I'm in the USA. Finding stock GTR cams is like looking for a Unicorn. If I do find them there won't be a big diffrence in price vs Aftermarkets :mad:. I have some stuff already just looking down the road.Pics of the stuff I have so far for the RB20 I'm not too worried about the lost of low end power, just a trade off you have to live with for topend.
BlueRB240 ... is that plenum for an RB20, looks neat!
Joel...are these figures right? The RB20 has 240deg - 7.8mm lift on both intake & exhaust , whilst the RB26 has 240deg - 8.5mm lift intake & 236deg - 8.2mm lift exhaust...is that right.
So yeh, the lift is really all thats really different between my R32 RB20DET cams and R33 GTR V-Spec cams. And even if the ramp rate was different, one would assume (i do a lot of that) that it becomes an issue as revs increase, not at idle or low revs (????)
Im over it now, ive only driven the car about 6 weeks this year, and it has cost me too much money (not alot compared to what most spend, but more then i lile spending)...just want to enjoy it again like i use to when it had the std turbo/injectors/ecu etc etc
Yer thats right, well according to tomei.
http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
Whats considered the Vspec N1? (as per the above link) ???
Maybe the higher ramp rate is causing problem with air velocity due to the RB20's slower piston speed?!?!? Theories.. :cheers:
What causes NA cars with big cams to have poor vacuum at idle...too much lift? Could it be a vacuum thing at idle...i dont know?
Camshaft overlap - when the duration is large and/or the centerlines are too close together.
Yer it is overlap.. Maybe the lack of piston speed in the RB20 (shorter stroke) isn't enough to create a decent air velocity hence fuel atomisation goes up the crap?!?!
Might start looking around to how ramp rate affects short stroke motors.
So any thoughts how these would work:
Tomei 256° / 8.50 inlet (PONCAM)
Tomei 260° / 8.50 exhaust (PONCAM)
on an RB20DET with a 420hp turbo...too big on the exhaust side, should i stick with 256 on inlet/exhaust.
Essentially if im not going to run GTR cams, i still want something to help beef up the mid-top end
as i own a R31 Rb20det ... cam duration being IN : 248deg and EX :240deg .. with 7.8mmlift
upgrading to the gtr IN : 240deg and EX : 236deg the 8.5mm lift .. will i actually gain anymore .. and is it possible to tune them with adjustable timing gears pacifically for more torque rather than top end power..
Well done to Waz on the successful setup ..sounds very promising for the other rb20 owners thats for sure
well when i had the GTR cams in (apart from not holding idle) when i drove the car it was super laggy down low, and didnt come on very hard at high rpm... which is what R31 power is describing. there were no other issues with my engine as when i re-fitted the std cams the car was back to perfect running order
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
