Hi all. Before anyone tells em to search, i have searched and have come up with so many different answers it's unbelievable.
> RB25 head going on to RB30 block.
> RB20/25 ARP 2000 head stud kit.
RB25 service manual states tightening in increments, loosening off to zero, then tightening to 25-34 NM and then angle tightening 90-100 degrees.
ARP kit says to install the studs hand tight into the block, put the head on and then lubricate the "stud threads, nuts and washers" with the provided assembly lubricant, then tightening the nuts in 3 equal steps to 108 NM.
Now i have a few questions about the procedure.
Are you supposed to put the assembly lube onto the stud thread before you put it into the block?
Do the studs really just get put into the block hand tight? (Some people use the a hex key and tighten the stud before putting the nut on, which makes sense to me)
I know this isn't *really* supposed to go in the forced induction section but as i am assembling the engine ATM i hope this will generate the quickest responses.
Thanks all.
https://www.sau.com.au/forums/topic/443864-arp-head-stud-torque-questions/
The stud is just hand tight in the block.
It shouldn't be done up at all all as bottoming it out induces stress into the block.
Doesn't need lube but will help it to not rust.
The lube is to ensure the correct tension is applied to the head. head If the nut wasn't lubed a lot of of your torque is wasted by friction, so not being used for clamping.
Use arp torque settings. They make make the studs and the different pitch thread thread and material need a different torque to stock.
Make sure you spray brake cleaner into the thread holes in the block, and then blow them out with compressed air, they need to be clean and clear of oil/coolant before you bottom the studs out in the block. The L19's had an allen key in the top, to tighten the studs in first. They don't need to be tight as Ben mentioned.
ARP torque settings and plenty of lube I agree with.
  • Like 1
The torque settings are slightly different when using ARP studs. so forget the nissan handbook which says 104ish I think.
clean all threads, lube all threads. with the studs just spin them in with your fingers. if you feel any resistance before the stud is properly seated then remove it and clean it up
I found the handbook image with the nissan specs on it, ignore them but use the same pattern
edit: what ben said
Edited by Blackkers
Thanks guys. I knew about the sequencing and ensuring clean threads etc. it was just confirming that the studs are only hand tight in the block that had me stumped! In my mind something capable of withstanding 200,000psi isn't tightened hand tight haha (i know that torquing the nuts is what provide the appropriate clamping force btw)
So i will clean the threads in the block, apply assembly lube to studs, put them in hand tight, then just nip them up with an allen key before i torque everything to ARP specs.
Thanks guys.
Realistically, if it wasn't just so convenient to use threads to attach the studs to the block, you could just have them drop in with a quarter turn cam lock type thing like Ikea furniture for all that it takes to sit them in place -- if such an arrangement would be strong enough.
So hand tight is certainly enough.
  • Like 1
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
