ive been listening around my engine bay intensely recently as theres a strange scraping sort of sound going on. the front end bearing of my gearbox is very worn so thats making a noise but there seems to be a scraping sound coming from near the turbo area.
its sounds like the wheels are scraping against the turbo housing. is this realistic? the turbo still spools up well and theres no loss in power... could this scraping noise not be the turbo? its driving me crazy!!
https://www.sau.com.au/forums/topic/4439-turbo-wheels-scraping-against-housing/
as macka said ive got a t04. i swear the scraping sound is coming from the turbo! but their appers to be no side effects, and when you stand over the engine bay and rev the engine it goes away... i really dont understand. macka mayeb you should swing by a have a look hehe:burnout:
have u leaned it out the turbo by running hi-boost and not having enough fuel?
if so, you have probably melted your turbine wheel and caused the turbo to go out of balance which might be causing the exhaust wheel to hit the housing.
check the shaft for any movement (in/out & left/right) from the compressor side, or get it checked out by a turbo specialist.
good luck.
nah i havent leaned it out that much
im running 12-13psi with a bigger fuel pump, and AF's around the 10:1 mark.
i might get it checked by a specialist... i dont know if im being paranoid or not though, because sometimes i hear it and sometimes i dont. also the front end bearing of the gearbox is gone and thats making noise around the same area so im not sure...
if it was scraping against the housing would it
a) be loud
B) occur under all conditions?
Guest Cob@lt60
Hi dude,
My standard R32 turbo started doing the same/similar thing the other day.. It makes a squeeling/scraping noise only when the boost starts coming on (around .5 bar)
I'm taking mine to the mechanics on Wednesday 16th (if it lasts that long).. They said perhaps the exhaust wheel is unballanced or missing a "vein".
It's slowly getting worse i think.. :);) *tear*
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
