Ohhhhhh not long now, very excite. Prepare for rain because im washing the blue beasty on the friday so im predicting rain on saturday. Got the day off work so am 100% gonna finally make a Tech arvo :P
  On 23/07/2014 at 1:02 AM, FeZ25 said:
Hey Terry,
Gonna have to pull out. Family arrangements decided to come up last minute. Hope you guys have fun, will be a blast.
I am disappoint!
You could have tried to sell Adam my old turbo :P
ADDENDA
* Adam has taken note of all your qualms/questions and intends to answer them all this Saturday
* Adam has gone to the trouble of inviting other ECU Manufacturers and Distributors to come and speak for a maximum of 30 mins each
* ECU Manufacturers and Distributors at their own discretion may be handing out "Specials" on the day, upon a purchase eg Wideband AFR Kits
* Merchandise and Promo Material will be on offer for attendees
* Mini-stalls will be set up from 1pm onwards if you wish to arrive early and talk to an expert
Many thanks go to JEM - Adam Neish - for stitching this together.
Pros (and Cons) without bias is the order of the day.
Remember, these presenters value SAU.NSW so highly that they wish to make our day memorable.
Win-Win !
  • Like 1
  On 23/07/2014 at 10:06 PM, Terry_GT-R34 said:
ADDENDA
Win-Win !
That is awesome Terry!
Really looking forward to this.
Hats off to Adam :)
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
