Hi all,
I was wondering what kind of injectors i would need to suit my current setup, my current mods consist of:
BMC Airfilter with Heat Shield
NGK Iridium Plugs
FMIC
Turbosmart E-Boost
3" Exhaust with Dump Pipe and Hi-Flow Cat
Greddy Plenum
Bosch 040 (I think) Intank Pump
My turbo just died and i have purchased a new turbo, it is a RB25 turbo that has a new Ball Bearing T3/T4 Core good for up to 22psi. I know that with my stock injectors and computer i wont be able to run this turbo at its full potential. However i am buying a Power FC and i am buying injectors to.
My Question is, because i have the Greddy plenum i can get a GTR Fuel rail and run top feed injectors, would the 444cc injectors from a GTR be sufficient to run this turbo at full boost or would i need bigger injectors then these again? My aim is as much power as i can get from this current turbo and setup, all help is much appreciated, thanks
https://www.sau.com.au/forums/topic/44394-what-injectors/
Hi all,
NGK Iridium Plugs
FMIC
Turbosmart E-Boost
Greddy Plenum
What engine is this?
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-907989
ive been told a good rule of thumb is look at what horsepower you would like to achieve then match them with the same figure injectors. eg 550 hp then get 550cc injectors etc
i was actually discussing this tonight with a friend and this is my theory:
If my 6cyl rb25 flows 550hp of air and need a total of 3300cc of injectors (6cyl x 550cc) will my 4cy sr20 which also flows 550hp of air need a total of 3300cc of injectors? yes. so that means it would need 4 x 825cc injectors (3300cc / 4cyl).
sustained air fuel ratios is what im keeping in mind. i think i am right in what i am saying :s im not too sure so correct me if im wrong :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908132
sustained air fuel ratios is what im keeping in mind. i think i am right in what i am saying :s im not too sure so correct me if im wrong ;)
You got it. :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908134
oh sorry, its an RB25DET. Well at this stage i think anything over 300hp at wheels would be nice, i spose the best i can get above that is what im after, if the turbo does 22psi what kind of power will i be able to achieve with the injectors and power fc before the internals become at an unsafe point?
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908164
Firstly you need to remember that boost is simply a measure of restriction to airflow. It is airlfow itself that makes power, boost is really irrelevant. If you remove the restrictions in your engine, then you can make more power at lower boost. :idea:
Moving on to your question, 300 rwhp is ~225 rwkw and that is pretty much the limit of the standard injectors. RB25DET internals seem to handle ~300 rwkw (400rwhp) as long as the tuning is spot on. There are a number of threads on this subject, you really should do a search. :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908184
one more question, will the standard injectors and computer with that turbo get my 300rwhp?
With this information........
you expect me to be able to tell if the turbo is good for 225 rwkw? :wassup:
Sorry I can't do that, there are at least 20 different combinations of T3 and T4 turbines & covers and compressors & covers. I have no idea which set the turbo builder has used. Since they have gone to the trouble (and expense) of doing a ball bearing hi flow then chances are it is a worthwhile upgrade. My best suggestion would be to find out who did the work and ask them, they should have a record via the turbo serial number. :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908435
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
