At a guess it was tuned to run on a car that had a 2540 turbo on it. Other than that it's a case of plug it in and see how you go, from what I hear it can be difficult to get info out of Mines as to what exactly was done to the ECU.
https://www.sau.com.au/forums/topic/44395-mines-ecu/#findComment-908191
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
