G'day guys I have a series 2 rb25 and I'm looking at doing a 25/30 conversion and with everything I have read I still can't find info on what I'm looking for it's got a t66 turbonetics turbo 550cc injectors apexi power fc poncams and he all so said it has a upgraded I tank pump but unsure as well as a fuel reg and front mount now what I want to know is the the r34 neodet head much better ? As my tuner said that the 30bottom end will only like reving to 8000 and to just use my 25 head because it will only rev to 7500 anyway and it has much smaller ports and shit bowls? I'm not sure. All so my t66 I believe is quite out dated can any one recommend a good size turbo I want 300atw and will I achieve 300 with the mods I have ?
Edited by jeffero69
https://www.sau.com.au/forums/topic/443966-rb25-questions/
  • Replies 77
Popular Days
Have you searched.?
Everything you have asked has been covered.
I assume you you haven't searched.
There is even even an rb30 section.
3 people are currently doing builds , countless have already done it.
heaps of threads discuss the neo head benefits, even over an rb26 head.
How did your tuner pull the 8000rpm figure for the rb30? Based on what?
The info is all on here.
Do yourself and everyone else a a favor and read heaps.
If for some crazy reason you are still stuck we Weare here to help, but constantly going over the same shit gets tiring.
Edited by Ben C34
https://www.sau.com.au/forums/topic/443966-rb25-questions/#findComment-7301625
I have just been using google to search all my questions atm I have just joined and I'm currently going through the post now and reading what I can as for the 8000 rpm figure I have no idea where he got it from but he's a respected tuner for rb's. All so questions like will I need a different manifold for the neo head and that stuff I need to know about
https://www.sau.com.au/forums/topic/443966-rb25-questions/#findComment-7301634
As Superben said it has all been pretty much covered before mate. You are in the right place for starters, the 'forced induction' section, now all you have to do it scroll up to the top and you will see an RB30 section.
Spend a week reading through both of those (Use the search function if you are looking for specific info) and then come back and ask any questions you still have.
Plenty of people here are more than happy to help people out, but sometimes you just have to help someone help themselves ;)
Good luck mate!
https://www.sau.com.au/forums/topic/443966-rb25-questions/#findComment-7301645
thought they have a longer stroke....but they still rev.
https://www.sau.com.au/forums/topic/443966-rb25-questions/#findComment-7301660
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
