Hi All,
I've recently picked up an r34 GTR and have had a few minor issues (it's more annoying than anything).
The MFD screen intermittently displays some sort of error message in Japanese which I cannot understand and was wondering if anyone on this forum has come across the same issue in the past or know of what the issue is?
See the below photo of the message. It seems to just come up at random times but there is also a constant beep (pause) followed by another 2 beeps every 5 minutes without fail everytime I have the car running.
I should also mention that the car came with the factory sat nav upgrade which is virtually useless here in oz.
If anyone could help that would be much appreciated.
Cheers
https://www.sau.com.au/forums/topic/443978-help-r34-gtr-mfd-error/
No I don't think so. One minute if be running the gauges on the mfd and then all of a sudden the message pops up when I haven't pressed anything.
I highly suspect that it has something to do with the factory sat nav unit.
None of the buttons on my factory sat nav unit do anything when I press them so don't know whether that unit itself is buggered.
The beeping noise comes on as soon as I start the car and then every 5 mins thereafter. Have no idea whether the sound and the error message is related.
Thanks
Thanks
Think what you want.
I can read all but one word.
You can assume what it is.
I would bet it is insert.
Anyway, whatever.
I don't care if you believe me or not I also don't care if you fix the problem.
  • Like 1
Anyway, whatever.
Mate I wasn't having a dig at you or saying you weren't on the right track I was merely explaining the rest of the story so that I could try and see whether there was any link between the issues or whether they were completely unrelated.
Anyway appreciate your help.
Insert program boot disc is what it is saying. That unit cannot read its internal memory.
Quick fix, pull the plug on that unit.
Proper fix, convert to 2 DIN radio.
The mfd gauges are separate to the navi.
Shame you aren't in brissy. I would like a crack at fixing one of these.
Thanks all, much appreciated.
I've tried taking the disc out previously and nothing really changed.
Will definitely be switching over to double din in the future but have a few other things if like to do beforehand so will probably go down the route of unplugging the sat nav unit temporarily until I get around to the permanent fix.
Cheers
  • 2 months later...
Regardless it's the initial interaction that will always give off the lasting stigma..have a look then PM me ohhh yeah... ;)
It's pretty hard to accurately gauge a person by what they wrote on a forum. No sarcasm, facial expressions etc...
Have a look then PM me? What?
  • 5 months later...
Hey mate, never really ended up finding out what the actual cause of this was but I ended up just pulling out my factory sat nav unit and it stopped the issue.
Not sure whether you get the beeping noises at every 5 min interval? This went away as we'll for me as soon as I got rid of the sat nav. Strange you are getting the this issue without he sat nav? I think from what the guy have translated above, something related to an error loading the disc?
Sorry I couldn't be of more help.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
