Hi All,
I've recently picked up an r34 GTR and have had a few minor issues (it's more annoying than anything).
The MFD screen intermittently displays some sort of error message in Japanese which I cannot understand and was wondering if anyone on this forum has come across the same issue in the past or know of what the issue is?
See the below photo of the message. It seems to just come up at random times but there is also a constant beep (pause) followed by another 2 beeps every 5 minutes without fail everytime I have the car running.
I should also mention that the car came with the factory sat nav upgrade which is virtually useless here in oz.
If anyone could help that would be much appreciated.
Cheers
https://www.sau.com.au/forums/topic/443978-help-r34-gtr-mfd-error/
No I don't think so. One minute if be running the gauges on the mfd and then all of a sudden the message pops up when I haven't pressed anything.
I highly suspect that it has something to do with the factory sat nav unit.
None of the buttons on my factory sat nav unit do anything when I press them so don't know whether that unit itself is buggered.
The beeping noise comes on as soon as I start the car and then every 5 mins thereafter. Have no idea whether the sound and the error message is related.
Thanks
Thanks
Think what you want.
I can read all but one word.
You can assume what it is.
I would bet it is insert.
Anyway, whatever.
I don't care if you believe me or not I also don't care if you fix the problem.
  • Like 1
Anyway, whatever.
Mate I wasn't having a dig at you or saying you weren't on the right track I was merely explaining the rest of the story so that I could try and see whether there was any link between the issues or whether they were completely unrelated.
Anyway appreciate your help.
Insert program boot disc is what it is saying. That unit cannot read its internal memory.
Quick fix, pull the plug on that unit.
Proper fix, convert to 2 DIN radio.
The mfd gauges are separate to the navi.
Shame you aren't in brissy. I would like a crack at fixing one of these.
Thanks all, much appreciated.
I've tried taking the disc out previously and nothing really changed.
Will definitely be switching over to double din in the future but have a few other things if like to do beforehand so will probably go down the route of unplugging the sat nav unit temporarily until I get around to the permanent fix.
Cheers
  • 2 months later...
Regardless it's the initial interaction that will always give off the lasting stigma..have a look then PM me ohhh yeah... ;)
It's pretty hard to accurately gauge a person by what they wrote on a forum. No sarcasm, facial expressions etc...
Have a look then PM me? What?
  • 5 months later...
Hey mate, never really ended up finding out what the actual cause of this was but I ended up just pulling out my factory sat nav unit and it stopped the issue.
Not sure whether you get the beeping noises at every 5 min interval? This went away as we'll for me as soon as I got rid of the sat nav. Strange you are getting the this issue without he sat nav? I think from what the guy have translated above, something related to an error loading the disc?
Sorry I couldn't be of more help.
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
