Hi gents wondering what wing mirrors will fit the m35 stagea my mate slipped and grabbed my mirror last night and snapped it off. So was wondering if the g35 or 350- 370z mirrors would fit as a cosmetic upgrade?
Cheers for the help gents.
G35/V35 coupe mirrors won't work as the stageas/sedans share the same front and the windscreen is more upright where the V35 coupe has lower roofline so there for the doors are different and the bases are different.
If that makes sense?
Why not just grab a good condition 2nd hand one & get it painted to match?
Unless you are prepared to spend time modifying or customising the base area; anything else will just look half arsed in comparison.
There are some sweet looking covers that some people have; they have an LED blinker in them. Maybe check IM or Yahoo JP?
Yeah I'm most likely going the 2nd hand original part route. Was just looking at other options and I remember seeing somewhere on the net pics if stags in Japan with either g35 coupe, 350z or g36 mirrors like this one http://kumarom.blog115.fc2.com/blog-entry-224.html
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
