I've been having this issue recently where my battery would go flat after turning the car off after driving for short periods like 15 minutes or so. The car doesn't even click over and you could see the clock on the cluster fading in and out. After jumping the car everything else is fine. Could it be a sub or an amp causing the battery to drain?any help would be appreciated.
https://www.sau.com.au/forums/topic/444007-battery-dies-after-driving/
Yes.
It could be anything
Including your battery might be too old.
Your alternator might not be charging correctly.
I've taken the sub out , I'll see how it goes . I'll even put some distiller water in the battery as well
I'd say the altenator must be working or the thing wouldnt have any power to drive (seen as its completely dead after key off)
I'd look at battery first but you can also check altenator as well
If you dont already have one, go buy a cheap multimeter from Jaycar or Supercheap etc. Get the car running and check the Voltage with the car running. Check either by putting the meter probes on each of the battery terminals, or you can also put one on the positive out of the altenator and the other on a good ground in the engine bay. Between 14.0V and 14.5V means the altenator is working properly.
Get a second person and keep the meter somewhere as above, checking voltage when the car is turned off. The BEST a battery can get when off is 12.6V, but usually anything around 12V is fine. If you have less than this, and judging by your description you may have alot less, you have a problem on the battery or cables. Check that the cables/terminals are clean and have a good earth and good connection on the positive end as well. If that all looks good then I'd say its battery.
Another way to check the altenator as well is to check the R terminal. Best done with a test light, putting it to positive on one end and probing the R terminal should make the test light light up while the car is off. when the car is running, putting the clamp on ground and probing the R terminal should make the test light light up
Should be plenty of info to help you out, and multimeters arent expensive, and can be very handy
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
