Team Raceworx will be heading down to Wakefield Park on Monday the 26th of July for a trackday and we would like to invite our friends from SAU to join us :)
When: Monday 26/07/2004
Where: Wakefield Park
Cost: $80 for the full day + $40 for a Wakefield Licence if you don't have one already. The Wakefield Licence is valid for 1 year.
What you will need: Cotton Long Sleeve Shirt, Long Pants, Driver's Licence, Helmet (Helmet hire available for $20 per day with a $50 Deposit )
Reccomended: Plenty of drinking water, tools, racing gloves if you have them
Track opens at 9am, you want to aim to be there for 8:30am so that you can get registered and check over your car and remove all loose items before the track opens. Team Raceworx Drivers will also be more than happy to offer tips and suggestions for new drivers on the day.
Calendar Entry: http://www.skylinesaustralia.com/forums/ca...do=getinfo&e=67
Please register your attendance in the Calendar and leave a post if you would like to be included in the accomodation bookings
ACCOMODATION
Two Bedroom Family
Rates are for 4 people. Maximum occupancy is 5 people. Charges apply for extra guest. Bedding configuration is a queen size bed and two singles. Spectacular sized rooms. Facilities:
Air Conditioning
Bath (there you go Kelly :rofl:)
Cable TV (wOOt)
Dial-up Internet Access (if you need your SAU fix THAT badly :()
Fax/Modem Telephone Line (if your an uber geek with your own laptop :()
Hairdryer
In house movies
Ironing equipment (so Duncan can iron all of our clothes ;))
Kitchenette (basic facilities)
Opening Windows
Tea/coffee making (ohhh we're goign to need it in the morning)
$109 per room per night. Sleeping 4 people
COST WILL VARY DEPENDING UPON NUMBERS
List of people staying:
Tosh
Kel
Scott (TRW Member)
Chris (CRAVED)
Chris's mate
Chris's other mate
Chris's mate again
Nathan
Nathan's wife
Pete (Fatz)
Emma
Tim (CS_180)
Andrew (Merli)
Ken (Akira)
Jo-Ann
Alistair
Chris (RedX)
4 rooms have been booked. 1 room will be occupied by Pete (Fatz), Emma, Nathan and Nathan's wife and they will cover the cost of that 1 room themselves which leaves the last 3 rooms which totals $357 to be split evenly between 13 people
Tosh
  • Replies 302
the MR2 is just the sports model, slightly lower different spring rates, and a pod... driver isn't too experienced he's been there once. 1:18's i think he got down too
the sprinter does low 1:16's, made a few changes to it since then though! runs a CA18det
TOSH!!!!!!
NOT HAPPY JAN
how come i didnt get me an automatic confimation of entry???
of course im there and will c if i get get by without flatspotting atyre this time
oh and i can show u the racing line froma rear view of my car !! HAHAHHA
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
