S A U Celebrates R32 G T R 25Th Anniv - Part A - Videography
Day/Date:- Saturday 16th August
Time:- 7.00am until 10am
Venue:- Starkey's Cafe 43 Bridge Rd Stanmore
Who:- All SAUers and partners are welcome to this!
Whilst the Camera Crew Set Up at 7...
1) R32 GT-R drivers can park their cars along the east side of Bridge Rd facing south
1B) R32 drivers can park their cars along the west side of Bridge Rd facing north
1C) Other types of cars can park around the corner eg Salisbury Rd and surrounds
The complex inside has a wonderful Japanese style feel and so, we celebrate early, inside this complex.
2) Have a great sit-down or to-go brekkie at Starkey's Cafe Complex > chat
3) At 8, the first R32 GT-Rs begin to roll through the gates into this complex for your car to be video'd and photographed.
4) Each driver should...
* Remove your number plates if you're sensitive to having your car identified - optional
* Not rev excessively as there may be other tenants working - albeit very few
* Turn your low beams on as you come through the gates
* Drive at less than walking pace to grab as much footage of your car as possible
5) Each driver should...
* Stop momentarily as you enter the tunnel at the end of the "S" so the cameras can catch your rear lights
* Exit left at the end of the tunnel - not forgetting to put your number plates back on if they've been removed
6) At your own convenience, you and others can make your way up to Trackside Restaurant by 11.30am
Obey all road rules on the way to Trackside's address at corner of Manns Rd and Central Coast Hwy Gosford
See "SAU Celebrates R32 GTR 25th Anniversary Part B"
7) Spectators can hang around Starkey's to eat & watch proceedings or take a balcony view
* Donation Tin for "Cure Brain Cancer Foundation" > Monies to go through Scott aka "portaz"
* Obey Camera Crew Leader "RMBLBE" if he needs you to move aside please.
8) Videography will finish up by 10, so we can all make it up to Gosford.
* Thank you to Chris - Owner of Starkey's for putting on wonderful food at great prices - and letting us use the complex!
* Thank you Milan for donating your video expertise for free to the SAU.NSW Club!
* Thanks go to Performance Imports Mag & Performance Garage Mag for doing a feature on this!
  • Like 2
Will be there!
Your Dad has bought his BNR32 just in time Nathan.
We look forward to seeing it > subsequent video display of it.
Peeps, the OP has the correct name of the charity up now.
Us Execs just need to formally apply to be fundraisers of "Cure Brain Cancer Foundation" > be approved to receive monies on their behalf.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
