S A U Celebrates R32 G T R 25Th Anniv - Part A - Videography
Well it's 2 weeks to go, to the hour.
Who's for celebrating?
Cars from QLD and ACT as well as NSW.
Nice!
Matthew Everingham will be the shooter for Performance Imports and Performance Garage shooter magazines.
Milan Deo will be our videographer.
Unfortunately i will not be able to make this day - will be flying off to BKK for a few days with the wife for my birthday...
Have a great day guys and please please please take plenty of pictures...
I'll be there as well, Terry do we all rock up early and park near by or do you prefer people coming later then 7 or 8, not sure if you can park near the entrance there?
I'm planing to arrive around 8am?
Dave
Apologies, unfortunately I'm not able to make this significant event (after much hassling of Terry :/ for the past 12 months or so) sorry mate. Change in circumstances
One of my favourites from the test run. So I'll leave this here.
I'm certain it will be EPIC :thumbsup:
    • What blows me away, is watching some of the US guys, like Tony Angelo at Stay Tuned. LS1, buys a set of heads for $1200, drops a mild cam in, pulls all the electrics, drops a basic inlet manifold with a carb, MSD thing for spark, and roll it out to make 550hp.
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
