S A U Celebrates R32 G T R 25Th Anniv - Part B - Sns
GTR-N1
 Share
Register > PAY UP for this guys!
Is there any member or attendee here who knows how to play "auctioneer"?
Nick will post up some pics of Jim Richards' signed shirts to be auctioned off on the day for our SAU.NSW Club
And for our Cure Brain Cancer Foundation Charity, what we hope to auction off is this...
It's a 1996 Grange Hermitage.
Try researching how much this is worth before bidding!
Portaz is trying hard to secure models to pose with your R32s.
A prize from SAU will be awarded for 'Best Pose 'er Stance' methinks.
Get your 'imagination 'er fantasy' caps on!
Srsly or perhaps not so srsly the great Matthew Everingham will be taking shots for Performance Garage of your cars - with and without the models.
ahh that reminds me of the days when SAU had an autosalon entry....
sometimes it more than a girl on the bonnet to make a car look good.
But I assume the day is focussed on the club and it's cars, right?
  • Like 1
Sponsored by...
* Top Secret Imports (Well respected importers)
* JLM (Re service and compliance)
* Meguiar's (Motoractive)
* Members x3 of SAU.NSW donating a bottle of Penfolds Grange Hermitage '96 (a good year)...
On behalf of the club SAU.NSW and the charity Cure Brain Cancer Foundation...
We are going to celebrate!!!
In 2 weeks time, we celebrate!!!
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
