Details: Up for sale, ARX Wheels, 225 / 55 R18 in great condition.
Tyres are only 12 months old and have plenty of tread. All hub caps still intact.
Price: $600 ono
Shipping: No problem, at buyers expense
Call 0400720045
https://www.sau.com.au/forums/topic/444080-arx-wheels-18s/
  • 1 month later...
  • 1 month later...
  • 8 months later...
BUMP! - Looking for offers over $150
Completely forgot about these (just got married, changed jobs, moved & went on a holiday) until my previous employer called me this week to ask why I still had them stored in their warehouse.
Living in an apartment, I don't have anywhere to store them ergo this will be a massive bargain for someone.
Looking for offers over $150. I don't have the offset and I don't have the make off the tyres (the new fronts were 175 ea). At around 150 or over that detail becomes irrelevant.
I got 2 weeks to sell them
https://www.sau.com.au/forums/topic/444080-arx-wheels-18s/#findComment-7542920
  • 1 month later...
Nearly did, had a difference of the opinion of what offers OVER 150 meant.
Have decided to keep them, i'm ripping myself well off by selling them for anything less than $300.
Apologies, need to update/pull the ad.
https://www.sau.com.au/forums/topic/444080-arx-wheels-18s/#findComment-7576781
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
