adam96 Posted June 6, 2014 Share Posted June 6, 2014 This may sound a little odd but i was just curious to see if there was any device available on the market that allows you to control the rev range in which the valves open on an RB, similar to the well known device called the 'V-Tec controller'. Has anyone heard of anything similar or something that can be applied to an RB with the same principal? Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/ Share on other sites More sharing options...
scotty nm35 Posted June 6, 2014 Share Posted June 6, 2014 Valves open at all rev ranges. If you are talking about a VCT window switch, there are hundreds of options. Best controlled by the ecu imo. Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7304858 Share on other sites More sharing options...
Ben C34 Posted June 6, 2014 Share Posted June 6, 2014 A window swith would do it. And also achieve nothing. Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7304866 Share on other sites More sharing options...
MBS206 Posted June 7, 2014 Share Posted June 7, 2014 Well it would make the car slower, unless you change it at pretty much the same point the ECU does... Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7305784 Share on other sites More sharing options...
Ben C34 Posted June 7, 2014 Share Posted June 7, 2014 Well it would make the car slower, unless you change it at pretty much the same point the ECU does... But it would still be sure to impress.... Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7305787 Share on other sites More sharing options...
brat81 Posted June 25, 2014 Share Posted June 25, 2014 Vct runs through out the full rev range on neos not 100% sure on 33 25'de Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7321652 Share on other sites More sharing options...
iruvyouskyrine Posted June 28, 2014 Share Posted June 28, 2014 Vct runs through out the full rev range on neos not 100% sure on 33 25'de Wat? If it is active 100% of the time then it is absolutely pointless. Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7324304 Share on other sites More sharing options...
KiwiRS4T Posted June 28, 2014 Share Posted June 28, 2014 Vct runs through out the full rev range on neos not 100% sure on 33 25'de Not quite According to Tomei the R33 DE operates 1050 - 5700, the DET 1050 - 5400 and the Neo DE 0-5700 and the DET 0 - 5400 Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7324387 Share on other sites More sharing options...
Ben C34 Posted June 29, 2014 Share Posted June 29, 2014 Tomei are nearly correct. It's not active at idle, otherwise the idle is reasonably lumpy. It activates just off idle. On a neo. Link to comment https://www.sau.com.au/forums/topic/444095-vct-controller-like-v-tec-controller-for-rb-engines/#findComment-7324541 Share on other sites More sharing options...
